N6210 very low network level at 900Mhz Hi to All. Pls help repair N6210. At 900 Mhz very low network signal. at1800 Mhz work fine. Pls tell me this problem PA, switch or... How chek this parts. Thanks |
change antenna switch |
Jokkergsm is right |
Search mobile.box.sk for 6210 low signal fix. This tells you how to bypass the aerial switch without changing it. Mends internal but won't work well on external aerial after fix, though. |
Re: N6210 very low network level at 900Mhz Quote:
next i`ll warn you. |
moved from Hardware Repair |
Thanks to All, i try replace switch |
i have an 6210 that loses network after a call or during a call and sometimes needs reboot to get network back! Anyone know i can i solve this? Thank you |
Thanks guys, i replase switch and now work fine to smooter: try this solution http://codedata.box.sk/mobile.box.sk/rn621wss.zip , if not work i think you have PA problem |
