Old 05-07-2007, 05:42   #1 (permalink)
Crazy Poster
Member: 310194
Sonork: techsolutiongoa
Thanks Meter: 5
A strange problem with Nokia 3100
Hi, I have two 3100 nokia handsets both have a similar problem. They have been apparently dropped and everything seems to be OK on the display. Network shows normal on the display(network bars move up and down like a normal phone as you move the cell). However if I try to make a call the call doesn't go thru. besides if I try to call on it I get a message that the cell is out of coverage or "not reachable ". Any of u guys faced this similar problem???????? plz help me with a solution. Will be obliged
Thanks Brothers
Old 05-07-2007, 05:51   #2 (permalink)
Member: 99013
Thanks Meter: 52
Check PA with microscope,If any cracks on thae base of PA ,Change it .This might be the correct solution of you 3100
Gsmdoctorca
Old 05-07-2007, 05:53   #3 (permalink)
Pulax's Avatar
Member: 463891
Thanks Meter: 2
m8t better check the helga...just put a little heat......
gud luck m8t
Old 05-07-2007, 06:39   #4 (permalink)
techseeker"ems"'s Avatar
Member: 343227
Thanks Meter: 22
boss try to reset the unit to full factory. then observe. or reflow, reball or replace the PA, MJOLNER.
Old 05-07-2007, 10:30   #5 (permalink)
Crazy Poster
Member: 310194
Thanks Meter: 5
thanks
thanks for ur early feedback will try ur solutions and get back
Old 05-07-2007, 15:03   #6 (permalink)
hangout2511's Avatar
Member: 37352
Thanks Meter: 278
my experience is PA problem.. plz post result
Old 05-18-2007, 15:25   #7 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
keep some packing {black color ,very soft tape u can get with a new casing of any set} on flash rom.ur problem will be solved.many 3100 i repared through this method. ajmal kiani +923334267030
Old 05-18-2007, 15:31   #8 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
u can also solve ur problem to give some very gentle heat to flash Rom for 2 to3 minutes. but with a lot of care because it,s a very risky.after doing many sets dead u will find the actual methd
Old 05-19-2007, 07:17   #9 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
write solution
change pa and reball uem ur problem will defenately solve
Problem with Nokia 3100 pro-tech Nokia Digital Core Technology 4 ( DCT-4 ) 3 06-16-2008 20:34
Strange problem With Nokia 3100 Kanwalgee MT-BOX 5 07-24-2006 09:17
Problems with nokia 3100/3120 don't work wgmmmx Universalbox 2 03-14-2006 09:28
problem with nokia 3100 pentagono Nokia Digital Core Technology 4 ( DCT-4 ) 3 10-22-2004 16:55
Strange problem with Nokia 3310 Chawek Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 02-27-2002 22:47
Page generated in 0.20475 seconds with 10 queries
