N70 Baterey empty dear all.. I have N70,baterey indicator on display full.but when I use calling phone goes off and affear on display BATEREY EMPTY PLEASE RECHARGE. my baterey ok. I need solution for my phone..... Thanks. |
shorted fault please check or virus try format fs then scan mmc |
brother it's pa problem. |
HI all sir 1st change batrry conacters 80% solve uer problem.......:) |
its problem when u make a call or when your phne is transmit... so i agree if the ptoblem on PA br |
i m agree this is virus problem plz scan your mmc if no solv this problem u flash same ver i hope your problem is shotout permanent |
just change p.a 100%solved |
If Phone shows Batter full then there may be battery problem , change battery. otherwise check the how much voltage is coming at battery connector. if it is comming more then 5 V dc . then there may be problem of TAHVO IC. change the TAHVO IC. IT WILL RESOLVE YOUR PROBLEM 100%. |
just change p.a 100000%solved. .post reply |
