N70 Camera Problem. Unexpected error occured.Power off the device and restart. Dear Gurus, Anyone encountered this problem before? Phone is water damaged. When I place back cover and slide it down to use Back camera, I will get error message "Unexpected error occured.Power off the device and restart." However when I DO NOT put back cover and camera is in front camera, it is ok. (After I restart the phone.) I have tested voltage of C1472(4.0V), C1473 (1.5V), R1475 and J1471(1.8V) and seem to be ok. Is it ok for C1473 to have 1.5V since in the service manual, it is suppose to be 2.8V? I checked with 6680 service manual which uses the same N7505(LP3990LDX-1.5NOPB), the correct voltage is 1.5V. Anyway, I have replaced N7505 as well. I have also replaced Camera. Other test is TAHVO to R4408(VIO=1.8V) to S5202 is correct. |
you have to change the "level shifter" IC near the display connector. |
Hi reji, Problem solved. It is not a faulty "Level Shifter" (N1474) but just bad contact at I/O_VB1 and I/O_VB2. Thanks for the tip. Cheers. |
please help please show the solution with picture sorry i don't understand thanks |
bro plz can you tell me what this means (I/O_VB1 and I/O_VB2) i can't get u i also have the same problem can u tell me the solution or any picture plz |
refer to the schematic and look at N1474. You will see the names of the track there. |
plz can u send me the link from where i can downlod n70 sematic diagram i dont have can u plz send it to me i m waiting thanks for ur solution:cool: |
change small ic near camera jack |
i had changed that ic which is near camera jack can u tell me another solution thanks |
mebe problem camra botten i mean beack cover push the botten and open the camra try 2 change .or some time problem rams try 2 rehot normal .sory english is very poor .br try and send me post result . ..::Mr Fone::.. |
i had solved te problem of back camera but same error is given when i start front camera any solutio plz plz help thanks for your solution:) |
1 Attachment(s) i got n70 with front cam problem and i solved it with this .check the pic |
1 Attachment(s) same on 6680 front cam problem |
thanks for your solution I tests ok |
thanks bro for your solution |
