Old 12-12-2008, 18:29   #1 (permalink)
Member: 560512
Question n70 not power on
my n70 power on\off not working i have check power switch ways its ok and if i charging ....lcd glow with light which indicate the charing display when i put power key it didnot power on. please give good suggestion
Old 12-14-2008, 21:19   #2 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
change display ic (right one)
Old 12-15-2008, 05:35   #3 (permalink)
Member: 894862
Thanks Meter: 21
change retu and combo
Old 12-15-2008, 05:46   #4 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
power switch fault replace first
Old 12-15-2008, 05:56   #5 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
you have cheak charging ok but not power on .use this pic
all the best
The Following 2 Users Say Thank You to sajithcellular For This Useful Post:
Old 12-15-2008, 06:06   #6 (permalink)
Member: 603921
Thanks Meter: 71
1st make an info using a box!! just to make sure if the unit is really working!!! if working,, replace power switch!!! reheat display driver,, sometimes when that 2 driver has short its hard to pwer on the unit
br.
Old 12-15-2008, 06:12   #7 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
its your power switch line problem
if you want you can change display ic (near power switch)
or,
if you want you can use jumper as shown in the picture
many time tested by me
post your result
The Following 4 Users Say Thank You to jimm07ct For This Useful Post:
Old 12-15-2008, 06:21   #8 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
Or check this solution
The Following 5 Users Say Thank You to venuno For This Useful Post:
Old 01-11-2009, 18:07   #9 (permalink)
Member: 436212
Thanks Meter: 3
i agree with jimm07ct its 100% ok
Old 01-11-2009, 19:29   #10 (permalink)
Member: 675717
Thanks Meter: 125
If you know the right way then post your openion otherwise not.
Old 02-04-2009, 09:10   #11 (permalink)
Member: 942114
thanks it workssssss
Old 03-05-2009, 16:03   #12 (permalink)
Member: 647578
Thanks Meter: 25
Attachment 181524
all the best
thank man.very good solution.work for me
Old 06-11-2009, 16:26   #13 (permalink)
Member: 1043511
Thanks Meter: 28
thxxxxxxxx good work
Old 06-11-2009, 22:20   #14 (permalink)
Member: 243158
Thanks Meter: 25
thx good work .
Old 12-30-2009, 16:50   #15 (permalink)
nykocam's Avatar
Member: 67494
Thanks Meter: 71
tnks a lot,nice solution.
N70 power on with ufs, with battery not power on krishnaaruna Nokia Hardware & Hardware Repair 17 03-02-2010 08:50
N70 Not Power ON John(LMT) Nokia Hardware & Hardware Repair 5 06-04-2008 03:19
help in n70 not power on fay00 Nokia Hardware & Hardware Repair 4 05-30-2008 08:34
N70 not power on an error with jaf need help jaf team skd_123 Nokia Base Band 5 ( BB-5 ) 3 04-20-2008 16:38
Page generated in 0.23824 seconds with 10 queries
