11-09-2008, 15:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | N70 Dead after display ic replace z4403 Kind regards, Vicky |
11-09-2008, 15:44 | #2 (permalink) |
Insane Poster Join Date: Dec 2007 Location: trissur/kerela/india.. Age: 31
Member: 654510 Status: Offline Thanks Meter: 21 | HAI bro 1st you check that the phone is charging ....... on/off path is going through the right display ic so if that ic is not fixed properly that set will not on...........check and post replay................... |
11-09-2008, 16:20 | #3 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | @naima Thanks for reply and good solution. it is charging ok so that display ic is not replaced correct thanks for make me relax and tension free. Kind regards, Vicky |
11-13-2008, 18:22 | #7 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | I have jumper power switch with RETU and it power up but display still not. I think I have put ic wrong side. I have white IC which have some words and line on side I keep word top but not work so I reverse it but still not plz guide me about it coz it is not clearly where is ***** of it? Waiting for your kind response. Kind regards, Vicky |
11-13-2008, 21:20 | #8 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 563001 Status: Offline Thanks Meter: 10 | I need a flash file for Nokia N70 Please I really need a help. I need a flash file for Nokia N70 The name of the nokia is RM-84/ N70-1 The version of flash file is 05wk07v31 With Nederland languish The problem is that the display is not working properly, if I put the mobile phone on I just see a Wight color and I bought a new one. And still the same And I went to the shop to change the display, and they say to me, that I need to flash first the mobile phone. After that the mobile phone gonna work properly Thanks Ralfe |
11-15-2008, 20:19 | #9 (permalink) |
Junior Member Join Date: Apr 2008
Member: 754449 Status: Offline Sonork: RSA Thanks Meter: 2 | just take another 2 new display ic and replace them together onetime. and yes keep ic's word on top side i mean that ic its got one line that line must be on your lefthand side when u look at the board. i think i gave u full detail. so please post the result. |
11-22-2008, 12:58 | #11 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | @imaran Thanks for reply. by keep ic words top it not work and by reverse (words down) and again resold, my problem solved so that mean white ic words are reverse as original. but power switch problem still not solved so just use jumper. Thanks all for reply and help. Kind regards, Vicky |
N70 dead after replacing retu ic | luyanda | Nokia Hardware & Hardware Repair | 2 | 02-27-2010 11:48 |
n70 dead after display ic change | mobileservises | Nokia Hardware & Hardware Repair | 11 | 01-30-2008 08:18 |
n70 dead after some heat on lcd ic | amardeepsahi | Nokia Hardware & Hardware Repair | 10 | 09-30-2007 16:12 |
n70 dead after display ic change | mobileservises | Nokia Hardware & Hardware Repair | 2 | 09-08-2007 19:21 |
K700 dead after change ic flash , how to handle with usb smart | CONG YANG | SonyEricsson (USB-Smart) | 1 | 09-05-2006 09:39 |
