07-10-2007, 21:27 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251073 Status: Offline Thanks Meter: 4 | N70 Display problem Im having problem with my N70 display, its not full white and lcd is working properly, but i get incresed brightness problem. Phone starts fine, and everything is working properly, no hangs and anything, just this brightness problem. Ive searched forums and didnt find anyone saying anything about solving this issue. Thx in advance. |
The Following User Says Thank You to ahbab For This Useful Post: |
07-11-2007, 07:34 | #2 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: K.S.A
Member: 444785 Status: Offline Thanks Meter: 170 | Quote:
chak lcd Connecter................... | |
The Following 5 Users Say Thank You to zahed1978 For This Useful Post: |
07-15-2007, 07:05 | #6 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471557 Status: Offline Thanks Meter: 13 | N70 Just Check The Connector And Driver In Lcd Before Changing The Omap Bro....and The Connection Of The Display In The Connector........ |
The Following User Says Thank You to shan969 For This Useful Post: |
07-15-2007, 07:57 | #7 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | Quote:
regards PUNEET14884 | |
The Following 2 Users Say Thank You to puneet14884 For This Useful Post: |
08-19-2007, 15:31 | #11 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | dear mukesh_b.Did you read post before answering???? your solution is for dead phones with white screen hanging, But phone in this thread is OK and ON. pls read posts first |
The Following User Says Thank You to .::AkhavanGSM::. For This Useful Post: |
08-19-2007, 19:23 | #12 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | it is 100% working & checked. i think u might miss something or doing wrong jumper for any of the problems be cool,calm & try sensibly & u do get the best out of it but the condition is u might be a professional one not -----------? write now the problem is color brightness but the diagaram of ours is used wrongly by a layman? is it clear now the solution for the problem is : * firstly check it with another display then proceed as follows * change the boosting coil but if the prob remains same then * change the lit ic. |
The Following User Says Thank You to xtremeburaq For This Useful Post: |
08-19-2007, 19:46 | #14 (permalink) | |
Member: 483748 Status: Offline Thanks Meter: 47 | Quote:
yes, u r right but if he removes both smps & ape regulator & makes 1 jumper for vcoreA where from the ape regulater gets voltage, then u have to follow our jumper which is 100% ok. becz ape regulater getz voltage too. | |
08-19-2007, 21:29 | #15 (permalink) | |
thk........4 suggestion.........but think before posting atleast.....count does n't matter regards PUNEET14884 | |
The Following User Says Thank You to puneet14884 For This Useful Post: |
Nokia n70 display problem please help !!! | hanifhalai | Nokia Hardware & Hardware Repair | 19 | 07-30-2010 13:41 |
n70 display problem | zrnakhan | Nokia Hardware & Hardware Repair | 7 | 04-15-2008 01:15 |
N70 Display problem after charge | jacqk666 | Nokia Hardware & Hardware Repair | 3 | 01-06-2008 14:43 |
N70 display problem | 7th_gear | Nokia Base Band 5 ( BB-5 ) | 13 | 05-22-2007 08:43 |
water damage N70 Display Problem | mecky2000 | Nokia Hardware & Hardware Repair | 3 | 12-08-2006 04:06 |
