..::n70 fake charging (no charging volts)::.. 1 Attachment(s) n70 fake charging(no charging volts) i change tahvo ic,rehot retu,but still very low charging volts,see this picture one print missing,this print cause problem? ..::HUM::.. |
any solution?????????????????? ..::HUM::.. |
..change THAVO...work 100%.. |
if phone is showing charging bars then problem is THAVO ic hange it similar with n72,6680,6681,6630.... br smartengg |
RETU has also role in charging, so plz change the RETU. |
only change THAVO be ok |
the set is working ok,the only thing is that when i connect charger some times it show full battery indication sometime continue charging,the battery timing also ok,the only thing with customer is that y it not show full battery indication, otherwise set works ok. ..::HUM::.. |
..change THAVO...work 100%..:) |
change thavo 1000000000% |
i tried changing taho but no luck still the volt is low any new solution please |
masi 786 re hot thavo first then change thavo ic |
1 Attachment(s) firstly change 'tahvo'.mostly problem will be solve.if problem same then change red marked diode shown in picture.i repaired successfully. try it and post reply. wbr shoeb |
sir help sir plz tell me whats the work of pA POWER AMLIFIER AND ANT SWITCH PLZ SIR THANK YOU |
Thanks man good work................ |
just change tahvo uoy can take it from another set , becarefull when change tahvo , because over heat will damge other side board omap.take care |
