04-06-2009, 08:18 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | N70 hang whean i insert memory card phone is ok just hang only whean i insert mmc. I aso doing full flash phone but not solve. pls any one help me |
The Following User Says Thank You to Shantobhai For This Useful Post: |
04-06-2009, 09:33 | #12 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Brother, Heat up the UPP with AMTECH GEL ON TOP and heat up the 4 corners mainly. There is risk. But do it carefully, Cool the PCB under FAN. And then check once again. Also clean the PINS of MMC Socket very well. Also check the capacitors connected between CPU,UEM & MMC. Post result. amit123 |
The Following User Says Thank You to amit123 For This Useful Post: |
04-06-2009, 12:51 | #13 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Quote:
BRO MAY B UR MEMORY CARD JECKT IS SHORT OR WATER DEMAGE OTHER I SOLVE THIS PROBLEM WITH FOMATING MEMORY CARD FOR RESION OF VAIRUS U SAY THERE IS NOT PROBLEM WITH MEMORECARD SO LAST ITS MAY B MEMORE CARD JECKT PROBLEM CHEK IT. . . . . Guljee | |
The Following User Says Thank You to guljee786 For This Useful Post: |
5300 phone hang after insert memory card | obl6 | Nokia Hardware & Hardware Repair | 1 | 03-25-2010 07:33 |
v360 hangs when inserting memory card | yurais | Motorola Hardware Repair | 1 | 12-01-2007 05:55 |
L7 Hang after insert Memory Card | Nadjombe | Motorola Hardware Repair | 9 | 11-02-2007 12:19 |
v3x Hang after insert Memory Card | najafi | Motorola Hardware Repair | 3 | 08-22-2007 12:20 |
3650 hangs when inserting memory card | forhike | WD2 & APE (Symbian Phones) | 2 | 08-21-2003 03:02 |
