02-02-2011, 19:38 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Seraat-e-Mustaqeem Age: 38
Member: 228476 Status: Offline Sonork: 100.1575078 Thanks Meter: 114 | N70 loudspeaker on when make call I get Two N70 with same problem. Problem is that When make call its loudspeaker starts and " 4 " button work automatically. i flash it and also changed its keypad ic and also have changed its keypad board. have anyone have its solution???? plz share as soon as possible. |
02-03-2011, 12:58 | #3 (permalink) |
No Life Poster Join Date: Jan 2011 Location: INDIA>GUJARAT
Member: 1497850 Status: Offline Sonork: 100.1601368 QQID:21952428 Thanks Meter: 1,575 | first restore it with *#7370# code 12345(normal) then change ur inner key pad . Ur proublem will solved 100% same fault then last finally change keypad ic with carefull. |
The Following User Says Thank You to idrish911 For This Useful Post: |
02-03-2011, 14:43 | #5 (permalink) |
No Life Poster Join Date: Dec 2009 Location: GSMKSA Team
Member: 1178222 Status: Offline Sonork: 100.1602620 Thanks Meter: 467 | bro change og babile pad (inner key pad ) not solve then change lcd holder not ok then make jumber near key pad connector ic 6 leg ic 100% solve tested many many set not ok then i think this omap problum change or reboll omap |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
