07-17-2007, 18:16 | #5 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Phnom Penh(CAMBODIA)
Member: 447590 Status: Offline Thanks Meter: 378 | What U mean no access? After manual search come out Ur home network then after selected NO ACCESS?If yes just re-heat hinku/vinku or follow the picture have been sent. |
The Following User Says Thank You to chandy pok For This Useful Post: |
07-18-2007, 13:15 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | One more time, i have just faced the same problem & it was solved by reflowing RAP3G , i know that a lot of you may thought it is a far suggestion but this is wrong, more the chip is bigger more the chance to get unsoldered & result a lots of problems ... |
07-20-2007, 12:51 | #10 (permalink) |
Junior Member Join Date: Jun 2007
Member: 531288 Status: Offline Thanks Meter: 2 | no droped & no water damage.. Just suddenly no network. sometime got network but can't call in...I also use mt-box flash and write pm but not use..thanks |
The Following 2 Users Say Thank You to s9966 For This Useful Post: |
07-20-2007, 13:05 | #11 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | Some times i decide to do a totally reflowing job, so yesterday i was having the same problem; i reflow antenna switch, PA, HINKU, VINKU at once (using flux & to give each component an extremely little side move) & it works great, so if you would like to do the same go ahead, if you are worried reflow them one by one then test, good luck ... |
The Following 3 Users Say Thank You to mobilagy For This Useful Post: |
N70 network noo access | dev452005 | Nokia Hardware & Hardware Repair | 1 | 11-25-2009 07:52 |
1200 network no access | tiju kkm | Nokia Hardware & Hardware Repair | 9 | 04-05-2009 08:39 |
6630 Network No access | Chandreshswami | Nokia Hardware & Hardware Repair | 2 | 10-07-2008 08:33 |
T630 Network No Access | taaz | Cruiser Suite | 2 | 03-01-2006 10:26 |
t20, t28, t29 no network, no access | gibso | Old Ericsson Phones & Sony Phones | 2 | 10-26-2003 12:39 |
