06-06-2008, 07:10 | #2 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
For example: > You are going to erase 1600. > You mistakely selected 1208 in UFS Suite. > You pressed Erase Button. > Flash IC of 1600 will be erased as the IC of 1208 and may cause to delete Permanent Memory Area or may cause corruption because every set has different flash areas. > After erasing you may realize your mistake but it can not be undone. > That is why UFS warns you before erasing any phone. At last, I want to clear that you may Full Erase and Flash your phone to turn it on but may need to write PM file. Br, Shadab Ahmad | |
06-08-2008, 04:45 | #8 (permalink) |
No Life Poster Join Date: May 2008 Location: philippines
Member: 773960 Status: Offline Thanks Meter: 529 | we can still flash the phone after erasing..but we must write also pm....file..why? so that our phone will still have a signal..because if we erase the flash after writing there will be no signal if we dont write pm.. |
06-08-2008, 10:50 | #10 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Ian with sigma xi.What we will do in 1200,1208,2760,1650,& many more new model amol_sm????????? Thankz. Xtreme Mobile. BRB. |
is it true that i can change the imei on my 3g iphone? | gordyboyuk | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 04-16-2009 20:39 |
Is it dead phone cant flash | sharaz191 | MT-BOX | 4 | 05-28-2007 11:08 |
is it true that the box can unlock only fews pic's of NEC411 each month ? | cellularman | FuriousGold | 5 | 07-13-2006 10:39 |
