07-10-2008, 05:08 | #1 (permalink) |
Junior Member Join Date: Jan 2008 Location: philippines Age: 34
Member: 693658 Status: Offline Sonork: simple but rock Thanks Meter: 1 | n70 no memory inserted help |
07-10-2008, 09:18 | #2 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: bahrain
Member: 734871 Status: Offline Thanks Meter: 1,348 | Quote:
restart your phone after insert the mmc,if it is fine...change the switch near battery connector.then post me result. | |
07-10-2008, 11:28 | #3 (permalink) |
Junior Member Join Date: Mar 2007 Location: Pakistan
Member: 469552 Status: Offline Sonork: 100.1583852 Thanks Meter: 7 | having same problem having same problem but in my case card is working but when open hot swap door it wont msg 'to remove memory card press ok' i have to restart the mobile, i was thinking the same about the hot swap switch what u guys say let me know thnx |
11-03-2008, 08:43 | #4 (permalink) | |
Registered User Join Date: Mar 2007 Location: NILAMBUR(INDIA)
Member: 474045 Status: Offline Thanks Meter: 9 | Quote:
memory card switch replace & shot (2 point short) | |
11-03-2008, 08:56 | #5 (permalink) | |
2:momory card switch replace or shote 3:momory card ic volt checking 4:momory card ic replce or short 5map rehot | |
n70 no mmc inserted | .::ADNAN440::. | Nokia Hardware & Hardware Repair | 4 | 07-27-2010 15:32 |
5310 no memory inserted | Nouzer | Nokia Hardware & Hardware Repair | 13 | 06-22-2010 04:16 |
n70 no memory card inserted done with this solution | brownline28 | Nokia Hardware & Hardware Repair | 3 | 02-02-2010 06:06 |
N70 no light need help | jbh_143 | Nokia Hardware & Hardware Repair | 5 | 03-08-2008 09:19 |
