12-26-2007, 10:26 | #3 (permalink) |
Insane Poster Join Date: Nov 2006
Member: 390359 Status: Offline Thanks Meter: 30 | answer is here: how this problem occurs?? first you shoul try software, full flashing and write pm if still same rehot or reball inku and hinku ic (under camera, right of mmc socket) then change pfo and apply arun's solution. |
The Following User Says Thank You to zeking82 For This Useful Post: |
12-28-2007, 10:40 | #5 (permalink) | |
Junior Member Join Date: Sep 2007
Member: 581194 Status: Offline Thanks Meter: 18 | Quote:
Br Boim80 | |
The Following 15 Users Say Thank You to boim80 For This Useful Post: |
01-30-2008, 09:49 | #8 (permalink) |
Junior Member Join Date: Jan 2008
Member: 692937 Status: Offline Thanks Meter: 0 | I also have the same problem. Thing is, I already brought it to Nokia Care, and they told me that a cristal ic needs to be replaced, but it is next to a power ic which may further damage the phone. Will boim80's solution work for my problem as well? |
02-28-2008, 06:03 | #12 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | Quote:
bro, n-70 is bb5 set. and all bb5 set is risky to erase | |
04-25-2008, 15:10 | #15 (permalink) |
Junior Member Join Date: Apr 2008
Member: 756051 Status: Offline Thanks Meter: 4 | IF YOU Search The Networks Manually and It SHow All NetworksBut when you choose Your Network It Dont Want To Access THEN ITS THE (PA) CHANGE IT , AND WHEN YOU HEATING HEAT FROM THE UNDER CUZ THE (PA) IS SOO SENSTIVE AND IT DAMGED WHEN YOU HEAT ON IT |
n70 no signal some time show 3g on signal bar need help | /\/\A/\/| | Nokia Hardware & Hardware Repair | 2 | 10-14-2009 10:46 |
n70 no signal water damage | destri | Nokia Hardware & Hardware Repair | 5 | 01-14-2008 06:30 |
n70 no signal | ruvanw1979 | Nokia Base Band 5 ( BB-5 ) | 3 | 04-27-2007 18:13 |
n70 no signal | ruvanw1979 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 04-25-2007 11:38 |
N70 no signal | jakoy | Nokia Base Band 5 ( BB-5 ) | 7 | 06-13-2006 09:03 |
