12-04-2007, 17:13 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: KERALA
Member: 609370 Status: Offline Thanks Meter: 13 | 3230 Mcu Flashing Ok-error During Ppm Erased-help FIRST ERASED IN UFS-LOGS AS BELOW 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,0001007E,Amd 29BDS128J Fl1: 0x02000000-0x02FFFFFF,0001007E,Amd 29BDS128J Fl2: 0x04000000-0x04FFFFFF,27020111, Algorithm: w3_amd_b.fia, Ver: 4.19.0 Area1: 0x00000000-0x00FFFFFF Erased, Time: 02:00 THEN FLASHED-AFTER MCU FLASH COMPLETED-AN ERROR AS BELOW 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,0001007E,Amd 29BDS128J Fl1: 0x02000000-0x02FFFFFF,0001007E,Amd 29BDS128J Fl2: 0x04000000-0x04FFFFFF,27020111, Algorithm: w3_amd_b.fia, Ver: 4.19.0 Algorithm Ok, MSID: 849955ADC21CDB99385B741500 Decoded MSID: 3E4EBAF7-00189A49-A8000000 Encoded FAID: 265B8F58-CCA6B406-532DA685 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x00FFFFFF Erased, Time: 01:59 Area3: 0x02000000-0x02A9FFFF Erased, Time: 01:18 Area4: 0x02FC0000-0x02FEFFFF Erased, Time: 00:01 MCU Flashing Completed, Time: 09:19 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x02B00000-0x02EFFFFF Erased, Time: 00:30 Erasing: 0x04600000-0x0471FFFF ... Erasing Error: 10, at: 0x04600000-0x0461FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile I KNOW ITS FLASH IC PROBLEM-BUT I DONT KNOW WHICH FLASH IC? IN CIRCUIT SHOW THREE FLASH IC'S--D460,D461,D462. IN IT WHICH IS ADRESS """Erasing: 0x04600000-0x0471FFFF ..."""? HELP ME--THSNK U |
12-04-2007, 21:22 | #2 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 470292 Status: Offline Thanks Meter: 147 | Some times it is problem of file. First flash with another ppm file. I think your problem will remove....If not then Give heatup ics one after another without paste. Do not heat up ic more than 5 seconds. |
12-04-2007, 22:18 | #3 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | 3230flashing problem Hi, I think its not a flash ic problem it’s a file prob so you can apply select ppm china file and select ppm flash only when flash complete show nokia logo then again ppm flash with euro ppm file I think your problem will be solved…… Sopnil |
3230 flash ok but no boot please help | mani pkm | Nokia Hardware & Hardware Repair | 2 | 10-21-2009 04:54 |
6680 mcu flashing ok ppm not flash | rahmanp | Nokia Hardware & Hardware Repair | 2 | 02-27-2007 10:12 |
w550 & 3230 full flash ok but pc not on | TechPhone | Universalbox | 6 | 04-28-2006 08:54 |
Error during Full Erase of 7210 | Maurone | Twisterflasher | 2 | 05-26-2005 18:37 |
