n70 phone start-up faild contact retailar any brother give me a solution for n70 phone startup faild contact retailar. i finished softwere by lateste verson and rehot all ic but no any result.please any body give me perfect solution. |
You need write PM without 308 block, by JAF and SX4 autorisation. WBR ! |
cheak sp data post log hwk |
try the method as in the above posts if not ok.. (let me think that original rpl have been backed up in ur custody) just erase the whole flash using erase file( already posted in this forum) write down latest version to fone do write pm through SX4 option in jaf full factory reset and post your result regards, NEIL |
contact retailae brother, i do everything but no any result.i think it hardwere problem.thanks for post reply |
Bro 1st Erase Flash thn flash again with latest version try 2 flash with JAF Box . Hope ur prob solved |
dear try *3# power on ten post me |
bro i think rpl problem |
Mr.waqas_as ths procedure not working on N70 . *3# power on formatting procedure support on 3650,3660,6600,7610,6670,7650&Ngage Etc on S60 only ok bro . |
This does not wk for bb5 but for wd2 bro..... |
brother aap try tu karin *3# power then post me this is 100% work main nay bohat dafa dry kiya hai formating show nahin karta lakin ya formating karta hai |
try to change power ic and make format by hand only .. if same problem try to re-heat the rap3 ok .. hope it will help you |
i try to compleat flash but my n70 is still problem |
try whith the latest version and format after flach |
brother 1st:flash with letest version 2nd:format the phone 3rd:connect SX4 auth 4th:write pm(without 308 field) post result nazmul hossain |
