11-15-2009, 18:52 | #1 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1057695 Status: Offline Thanks Meter: 29 | n70 pwr problem i get n70 phone when u press pwr on the flash light is open i clean the phone very good 1- i change tahvo 2- i make the boot ic jamper 3- i change all capcter and resistance around tavho the phoe still as it not open and the flash light is open plz this phoe make me crazy what to do with it plz help me |
11-15-2009, 18:59 | #2 (permalink) |
Registered User Join Date: Jan 2004
Member: 49677 Status: Offline Thanks Meter: 53 | man its always boot ic pro some times retu has something 2 do with this fault but 2 be sure u have to do check WITH JAF and post result and make sure there is no short in mobile CHEAK IT WITH POWER SUPPLAY clean it very good B.R |
11-15-2009, 19:16 | #3 (permalink) | |
Member: 1057695 Status: Offline Thanks Meter: 29 | Quote:
r emove boot ic and make this short when i connect it to pwr supply it take curren lower than 10 MAmp the phone has no short when i put on jaf Changing mode...Done! Booting phone... Error sync the phone help me man what to do | |
11-15-2009, 19:24 | #4 (permalink) | |
11-16-2009, 13:12 | #8 (permalink) | |
the phone was water damge and his owner use it and the phone was ok but once it become as the condition when u pwr on the flash light on and the phone not open i clean it very good change retu change all compontent around retu (resistor and capecitor ) i remove the boot ic and make the short as i said all what i do mke no change you said check voltage help me more give apic of the component which i have to check | |
11-16-2009, 21:23 | #11 (permalink) |
Member: 1057695 Status: Offline Thanks Meter: 29 | hi friends i found the problem but i can't fond the soution there is no volt on this componet c2214=2.5v c2213=1.8v c2221=4.7v the most important one is c2213 why because it connect pwr to Rap3G and that why the phone not start up the problem how to solve this problem the only component which have 1.8 volt is c2802 and it also have no volt on it any one can give me answer will help me |
11-16-2009, 21:27 | #12 (permalink) | |
Member: 49677 Status: Offline Thanks Meter: 53 | Quote:
nokia 8210 pwr problem | de brain box | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-22-2006 10:32 |
n70 flahing problem | fonefun | Universalbox | 13 | 05-29-2006 14:12 |
