N70 still white screen after all the solution i've got one n70 white screen and i've changed display diode few times flash wit latest firmware many times change diode near connector big and small and make jumper as the solution i've search from tis forum after made jumper phone cant on... soi hav to remove jumper.... it solve so many n70 but not tis one atleast not tis one now reball ram... replace new lcds still no display but can make and receive call pls any solution thanks |
Maybe i help u Salam, (0300-6270112)(0321-6217607) first sms me if want make a call. ***** haffiz |
change the display ics.....as u said u can make calls... its display or display ic problem... try n post result.....br |
yes... its not software problem... If u switch on phone and it hangs on white screen.. then solution is different.. but if u can make calls.. and phone works with showing display.. it is L.C.D or Display Ic.. which is the right side of crystle ic.. on board.. |
i've change both side so many times already the ic's i use for other n70 works fine lcds taken form other n70 and new oso not workin |
1 Attachment(s) Quote:
6630 and 6680 has the similar ic's can be replace |
good work smartfone .......... |
1 Attachment(s) Which is the ic on the 6630? Can anybody show it to me on the pic below? Thanks in advance. |
@smartfone are u joking man ?? ;) |
If you know the answer to my question, why dont you post it instead of posting things " are u joking man ?? " If you think you are clever enough to fix a phone you dont even have to come to this site and waste your time broswing, spend your time to fix your phones instead of posting rubbish HERE. |
no hard feelin pls jus share and chill the 10pin u can only use the one for n70 but the small one is 5pin u can use 72 camera ic for replacement most nk 5pin works fine but till now i still yet to solve my pro any pro pls helpppppppppppp regards |
Ape flash ic is glued so check this out maybe some help removing it http://forum.gsmhosting.com/vbb/showthread.php?t=391852 WBR Francis Rodrigues The Mobile King Team |
[QUOTE=uneternity;2214724]i've got one n70 white screen and i've changed display diode few times flash wit latest firmware many times change diode near connector big and small and make jumper as the solution i've search from tis forum after made jumper phone cant on... soi hav to remove jumper.... it solve so many n70 but not tis one atleast not tis one now reball ram... replace new lcds still no display but can make and receive call pls any solution thanks[/QUOTE after all try only two possible chance to repair white light, first chk omap cpu, 2nd one ape flash ic... |
