n70 strange charge problem 1 Attachment(s) hi i received n72 two month ago that had charge problem,i check it's charge connector and it was shorted - and + pins of charge connector ,then i remove all C2000 & C2012 & V2000 and charge works again but today customer come that phone again with same charge problem ,- & + pins of charger connector shorted :confused::confused: here is picture of components that i removed ,signed with yellow circle i think that i must change TAHOV ,what's ur idea friends??? </div> |
pls give me help ,i need it urgently thx |
first u remove the fuse thn check +ve line short or not.if short change that diode.u must fix new diode otherwise after some days tavo ic will gone.it will show charging signal not charge store in battery. |
all sets if ur phone shurt plz chech ur batt connecter becuse if ur bat conecror conect the grund circut ur phone show the shurt ccircut...check |
i check battery connector,it's not shorted but charger connector in bottom of phone is shorted,i remove all parts in charge way but it's shorted yet i think that TAHOV must be change,pls see my picture and parts that i removed ,and help me |
only replace tahvo that will be ok |
Remove V2000 And Cross Track The 4 Balls.before That Change The Fuse Coz U Say Its Shorting |
i trace charge track and remove all components that can make problem,except TAHOV and it seem that TAHOV is responsible for this i'll change it and post result </div> |
i removed TAHOV ,and board is without this ic but it's still shorted,i confused as u see in charge ways in my attached picture,there is nothing else except F2000 & L2000,but charger connector (X2000) ,is shorted still. pls help me,where is malfunction ???!!!!! |
For Resolve Problem for charging in BB5 chech first software cause virus make this problem for charging |
phone is turned off,there is any software running ,it is 100% hardware problem,there is short circuit problem, WE ATTEMPT TO FIND SHORTED POINT don't misleading us:eek: thx for ur help;) PLS HELP ME </div> |
hi. any solution for this pb..? did u solve ur pb thread newstudent..? |
chek this solution http://www.u2ugsm.com/blog/wp-conten...0-charging.png |
