07-21-2007, 17:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: underground
Member: 113818 Status: Offline Thanks Meter: 29 | N70 Totally Dead TRY FLASHING BUT...... JAF version 1.98.25 Detected PKEY: 90003955 Card life counter: 98.13% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.AD, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Booting phone... Error sync the phone... AND SAME PROBLEM FLASHING VIA USB PLEASE SOMEBODY EXPLAIN WHAT IS PROBLEM THANKS |
07-23-2007, 19:49 | #7 (permalink) | |
Insane Poster Join Date: Aug 2006 Location: Beside malaysia Age: 45
Member: 333035 Status: Offline Thanks Meter: 2 | Quote:
REHOT can cause power failure if not done properly Firstly focus on this two ic (hopefully u did not rehot others parts) a)adjust ur ****er heater to 4.2, air to 370 (For n70) b)apply fluke (REHOT is very bad without fluke) c)**** one part at a time, play around with the distance from the ic to the ****er tips..(do not over heat.. but also take note, For n70 need longer time to MELT the solder balls) d)Use a pincer and PUSH sightly (I mean SIGHTLY) from the side of the ic... if the ic can move, take off the ****er immed... If u carry on, ur board will get overheat Take note: the above method is not from Textbook Try with care Post result | |
09-12-2007, 12:18 | #8 (permalink) |
Junior Member Join Date: Mar 2007
Member: 468280 Status: Offline Thanks Meter: 1 | Please help me out.I have a nokia N70 that power switch is uprooted with grounds.There is no ground available to resolder switch.The phone charges but cannot power up.Please give a diagram of the power switch ways.Thanks in advance. |
N70 total hot hot solution | naeem_skg786 | Nokia Hardware & Hardware Repair | 2 | 09-04-2009 16:35 |
S35v20 total dead help please ! ! ! | sasa2002ge | x1x to x45/x50 | 0 | 11-20-2001 17:49 |
C25fw61 total dead !!! | Trebor | x1x to x45/x50 | 0 | 08-12-2001 21:54 |
totally dead c35 | frankn | x1x to x45/x50 | 14 | 03-31-2001 10:41 |
Totally dead Siemens S6 | SashaM | x1x to x45/x50 | 1 | 03-11-2001 13:33 |
