Old 06-19-2009, 13:30   #1 (permalink)
Member: 441074
Thanks Meter: 13
1650 contact service
Dear bros..1650 first full files eresed,after flash with JAF....
now.....it contact service......any other solutions....pls telme...............
The Following User Says Thank You to sathi303 For This Useful Post:
Old 06-19-2009, 13:40   #2 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
write pm file than unlock it
it,s will ok
stan1comm
Old 06-19-2009, 13:57   #3 (permalink)
Member: 187199
make sure your pm is good............
Old 06-19-2009, 13:59   #4 (permalink)
Member: 394974
Thanks Meter: 28
hello friends i have a 1112 with contact service i have already flashed it i have also flashed in new pm is there any other solution for that all suggestions are heartly welcome
Old 06-19-2009, 14:11   #5 (permalink)
Member: 952440
Sonork: 100.1581847
Thanks Meter: 1,870
Only use these Methed ,
Full erase,
Full Flash,
Write Pm,
Do Unlock,
if you need working pm files click here
use thanks button
Old 06-19-2009, 15:15   #6 (permalink)
kashif_khatri's Avatar
Member: 572614
Thanks Meter: 144
write pm and unlock with jaf u r problem solve.
Old 06-19-2009, 15:34   #7 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Unlock the set.
U r problem will be solve.
Old 06-19-2009, 17:00   #8 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
Full earase the phone & flash the phone with latest version. write pm & unlock
if still same then its hardwer problem uem ic faulty
Old 06-19-2009, 17:07   #9 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
Whom with DCT4 of models Contac service then should man comes afterwards Unlocken!
Old 06-19-2009, 17:15   #10 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Unlock with jaf using latest version,working many times
Old 06-19-2009, 17:27   #11 (permalink)
zeel_zeel's Avatar
Member: 205427
Sonork: 100.1580937
Thanks Meter: 1,162
Post your JAF log here, so someone could see the problem..
Old 06-19-2009, 19:31   #12 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
write good pm file. thanks....
The Following User Says Thank You to chamak-liton For This Useful Post:
Nokia 1650 contact service fonesintones Nokia Hardware & Hardware Repair 90 02-18-2011 14:51
1200 - 1208 - 1650 Contact Service 100% Ok sunnyarora Nokia Hardware & Hardware Repair 31 11-19-2008 08:33
1650 Contact service :( can i fix this via Multi-Box??? the_frightener Multi-Box 16 02-25-2008 07:12
Page generated in 0.19483 seconds with 9 queries
