n72 BATTERY LOW repir were is zocus ic for repir n72 battery low any image |
battery low could be from many components inside the phone, try test first Thank You Byte ----- Cheap Hosting Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator |
[QUOTE=Byte;6125372]battery low could be from many components inside the phone, try test first Thank You Byte ----- Cheap Hosting Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator i need solution not a purchase new website pls give me solution n72 battery not stored |
i need solution not a purchase new website |
1 Attachment(s) Quote:
all the best . |
if you have a low attery problem, then you have to test many things at first, does the phone have higher power consumption than normal? is it in standby mode or in calling mode ? if you were able to answer these questions so we can proceed! Thank You Byte ----- Cheap Hosting Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator |
