N72 white screen solution Hello mates, I have Nokia N72 white screen problem. Phone Model: Nokia N72 Trouble: White Screen Check by inserting sim card and calling but no response checking keypad tones but no sound coming Action Taken: 1.reprogram new version result: successfully flash but still white screen 2. change lcd result: the same still white screen 3. Do the jumper method result: still white screen. any idea mates? |
this maybe is cpu problem but at this moment cpu cannot be change because after changing cpu set will become sim lock |
N72 white screen display I had that problem too. I reheat the cpu and also change the cryztal ic still white display. Any solution mates? |
I change the fuse glass and there is display now but after 30 seconds it displays again white screen. |
i just change the nokia n72 lcd with nokia n70 and n70 with n72 you will dont belive both sets are ok now |
Good news N72 LCD blank 3 Attachment(s) Hi!!!!!!!!!! Ur N72 power on is blank.Is it got ring sount? If yes U have to change both cristal IC.Placed beside backup battery.But If no,Just follow my picture.:) :) :) |
Thx for u sharing tat sulotion ~ |
thanks for the solution mate I will try it. |
asap |
need help for n72 when i press keypad blurred screen |
hello all the friends i am glad to join our community thanks to all |
N72 white screen prolam N72 white screen software problam ples help me???????:rolleyes: |
bro change cpu omap ... |
I have a n72 which was hang problem, then I flashed it but problem was same. Then I make jumper removing boot ic . Now phone is white screen. What to do now. Please reply me as early as possible. |
MCU SW : V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. APE Core: APE Var : Product : Nokia N72 Prd.Code: 0531541 Bpr.Code: 0530940 Prod.Sn : CTB323644 HW Vers : 5001 APE HW : APE Adsp: EM RETU : 32 EM TAHVO: 52 RFIC Ver: 150a160f DSP Vers: rolf_espresso_05wk07v29p1 IMEI : 359************** SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland nokia n72 nokia stay |
