Old 01-09-2007, 01:02   #1 (permalink)
Member: 59467
Thanks Meter: 4
Question N73 camera problem Neeed Help!!!!
I have N73 When open the camera give me White screen (no image)
I had changed the camera and still the same problem
What I can do to make camera work fine please help me
Note :
I had flashed the phone and still the problem
thnks for the best forum ever
Old 03-24-2007, 17:23   #2 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
U sorft this problem already?If still, Let me first.Ur N73 simply no camera or water damage or was droped?Urgent!!!! reply to me,I'll give good solution with picture.
Old 05-04-2007, 15:31   #3 (permalink)
Member: 91180
Thanks Meter: 22
hi,
i have droped N73 with camera problem display was broken i changed the display after that back camera is not working only black display. pl. help me.
Old 05-04-2007, 22:53   #4 (permalink)
MSG
Member: 132117
Thanks Meter: 3
it could be the shock of you dropping the phone could of damaged the track inside the pcb. You cannot tell, because the pcb will need x-ray.
All you have left is camera hardware accelerator.
Old 06-01-2007, 10:54   #5 (permalink)
Bastaphone's Avatar
Member: 385881
Thanks Meter: 40
please post the solution here! I have same problem with a water dropped set.
thanks in advance
br.Basta
Old 08-02-2007, 18:10   #6 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
i also have the same camera problem on N73 after falling into water, plssss help us,
thanks,
gibso
Old 08-04-2007, 19:24   #7 (permalink)
Member: 476053
Note :
try dis it work 4 me reheat the omap small one, NOT THE OMAP UPP OK,
Old 08-16-2007, 17:52   #8 (permalink)
rez7am's Avatar
Member: 386410
Thanks Meter: 52
chek this image
good lock
Old 08-16-2007, 18:10   #9 (permalink)
rez7am's Avatar
Member: 386410
Thanks Meter: 52
n73 camera
image is here!!
good luck
The Following 4 Users Say Thank You to rez7am For This Useful Post:
Old 08-16-2007, 19:28   #10 (permalink)
abu osama's Avatar
Member: 103786
Thanks Meter: 81
greet work my frind thanks
Old 10-30-2007, 05:31   #11 (permalink)
Member: 473380
Thanks Meter: 6
file corrupt bro......
got any other picture ?
tx ~
Old 10-30-2007, 08:41   #12 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
Originally Posted by rez7am View Post
image is here!!
good luck
Bro, reupload again ur attachment b,coz file corrupted cannot be open...
thanks
Old 10-31-2007, 15:50   #13 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
N73 no cam & svc
Try this solution.See the picture & post result.
The Following 2 Users Say Thank You to chandy pok For This Useful Post:
Old 10-31-2007, 15:59   #14 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
thanks greet work chandy pok
Old 05-06-2008, 08:51   #15 (permalink)
Member: 766684
Thanx Friends
thanx for u topic Harhowr
The Following User Says Thank You to abo_alrood For This Useful Post:
N73 camera problem Dee31 Nokia Hardware & Hardware Repair 88 08-14-2013 06:17
n73 camera problem.... del85 Nokia Base Band 5 ( BB-5 ) 3 11-25-2007 21:49
N73 camera problem wayne9198 Nokia Hardware & Hardware Repair 3 08-02-2007 19:20
n73 camera problem jbbasha Nokia Base Band 5 ( BB-5 ) 2 06-19-2007 06:34
N73 camera problem... achinxz Nokia Base Band 5 ( BB-5 ) 0 01-08-2007 14:24
Page generated in 0.38789 seconds with 11 queries
