Old 12-08-2008, 12:33   #1 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Nokia 7610 Start-Up Faild...... Pls Help
I habe a Problem... Nokia 7610
Start-Up Faild, Contact Retailer .....
I Tried to, Full Erese & Full Flash,
Rehit total board... Then Prob is still....
Now What can I do ????????????????????????????????
Urgent Reply me... Please......
Old 12-08-2008, 12:38   #2 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,390
use ufs ,1st full errege then full flash then write good pm then formet user areea then post result
The Following 7 Users Say Thank You to R@jusat For This Useful Post:
Old 12-08-2008, 12:49   #3 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
Nokia 7610 Start-Up Faild Re-Heat 80%
The Following 2 Users Say Thank You to sujan1050 For This Useful Post:
Old 12-08-2008, 12:50   #4 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
1=Full Erase
2=Full Flash
3=Write pm
4=Unlock
5=Formate
100% Tested Solution........
Old 12-08-2008, 12:53   #5 (permalink)
Cheater -Don't Deal with him-
Member: 677681
Sonork: 100.1590886
Thanks Meter: 232
try manual format power+*+3+call
Old 12-08-2008, 14:41   #6 (permalink)
Member: 350629
Thanks Meter: 18
try manual format power+*+3+call if not ok then formate with jaf
Old 12-08-2008, 14:44   #7 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Check post #3 brother its hardware u need to change RAM...........
Old 12-08-2008, 14:46   #8 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
only need write good pm .
br.
Old 12-08-2008, 16:45   #9 (permalink)
Member: 654510
Thanks Meter: 21
reball f11 flash ic.........
Old 12-08-2008, 17:04   #10 (permalink)
kurip's Avatar
Member: 526318
Sonork: dc2000
Thanks Meter: 42
first step :
*full erase
*full flash
*write with good pm file
*unlock
*format manual wih 3+*+call
if still problem
step 2:
change 11 flash ic
tested by me sair i hope can help for solution
Old 12-08-2008, 18:34   #11 (permalink)
Member: 919729
Thanks Meter: 5
only formate power+contact+*+3 in wite reply
The Following User Says Thank You to hytham_k For This Useful Post:
Old 12-08-2008, 18:58   #12 (permalink)
Member: 318781
Thanks Meter: 50
check your imei if ?????????????????? then get rpl all ok
Old 12-08-2008, 19:53   #13 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
Originally Posted by kurip View Post
first step :
*full erase
*full flash
*unlock
if still problem
step 2:
change 11 flash ic
this is a perfect solution......
Old 12-08-2008, 20:48   #14 (permalink)
Member: 919854
Thanks Meter: 3
from very past 100 times tested solutionAttachment 180768
pls helpppppppppppppppppppppppppppppppppppp meeeeeeeeeeeeeeeee
Old 12-08-2008, 20:51   #15 (permalink)
Member: 919854
Thanks Meter: 3
Thumbs down y5r
,mhgv
imat jama 101 start up hang pls help gsm_bds HTC & PDA WM( With Touchscreen) 2 05-07-2009 17:02
nokia 7610 start-up bassemzini Nokia Hardware & Hardware Repair 8 04-29-2009 13:37
Nokia 7610 Start Up Failed Contact Retailer Solution RAJAN62073 Universalbox 3 07-17-2008 19:24
Page generated in 0.19493 seconds with 10 queries
