Old 05-05-2007, 15:46   #1 (permalink)
Member: 379342
Thanks Meter: 16
6233 Ear Peice Low Volume
I have 6233 handset with low volume in ear peice. i have replaced the speaker and removed the protection resistor which grounded in speaker path. still same problem. any solution plz.
Old 05-05-2007, 17:02   #2 (permalink)
MSG
Member: 132117
Thanks Meter: 3
theres 2 caps and 2 resistors left on the line.. do u have manuel, to see ?
Old 09-11-2007, 22:59   #3 (permalink)
Registered User
Member: 143939
Thanks Meter: 264
Chech cover over speaker
Old 11-22-2007, 07:30   #4 (permalink)
Member: 599598
Thanks Meter: 2
hello friends already i sent the n6233 speakr sound is very low,i change middle cover n left side resistor.pls help me. by ansusha
Old 12-15-2007, 11:24   #5 (permalink)
Member: 6733
soame problems
i have the same problem low speaker
please any one help us with a pic what to change or where is the damge
i changed the speaker and the chasess and the speaker filters but no change
Old 02-04-2008, 13:47   #6 (permalink)
Member: 255625
Thanks Meter: 13
Question
Are solve your problem?
if yes then how you solved this prob?
because i have same problem
abhishekh
Old 06-05-2008, 08:04   #7 (permalink)
Member: 720413
Old 06-05-2008, 08:48   #8 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
@All
Just Search:http://forum.gsmhosting.com/vbb/showthread.php?t=499919
Problem surely in retu ic.somtimes it will be solved by rehot retu ic.if not sorted then have to change/ reball.I faced 10 mobile with same problem and i get sucess on 2 mobiles by rehot method.hope it will helpful to you.
br
Karan
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 06-17-2008, 14:41   #9 (permalink)
Member: 255625
Thanks Meter: 13
Wink
Originally Posted by KK Mobile View Post
@All
br
Karan
Thanks
I will Try ..........
abhishekh
Old 03-05-2009, 13:07   #10 (permalink)
Member: 269306
Thanks Meter: 4
for 6233 with low volume earpiece i solved the problem by
using a 6500s earphone on top of the board , you just have
to cut some plastic away to fit it , it will sound louder
because its closer to the ear.
hope it works 4 you too.
Old 03-05-2009, 16:25   #11 (permalink)
Member: 969106
Thanks Meter: 7
change huddy
& enjoy
6233 ear speaker too low and 6120c mmc jumper plz need shani72 Nokia Hardware & Hardware Repair 1 01-03-2010 16:53
6233 Ear Peice Low Volume help me palav Nokia Hardware & Hardware Repair 0 09-21-2009 12:10
6233 low volume Pratheesh T K Nokia Hardware & Hardware Repair 3 07-28-2009 07:26
6233 ear voleum low don160 Nokia Hardware & Hardware Repair 5 07-28-2008 16:16
6233 ear speaker sound low lohith03 Nokia Hardware & Hardware Repair 0 07-17-2008 07:32
Page generated in 0.19790 seconds with 9 queries
