Old 07-19-2007, 17:03   #1 (permalink)
Registered User
Member: 76882
Thanks Meter: 56
n80 camera hardware falure problem
hi 2 all
n80, when camera on phone showing hardwre failure restart camera.
i changed flex, but still same problam, set was water damage only frount
board. any solution plz help me
Old 07-19-2007, 18:13   #2 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Arrow
If you have the chance to replace the upper board so you get the problem solved easily , otherwise you will have to check upper board components; front camera connector, B2B connector, the two small filters shown in attached picture & by the way i have once got the same problem & it was the left filter missing on board so i have jumper it like shown with red link in picture, so if it's damaged you will have to replace it if you could found spare part or to make jumper, also the other filter but to take in consideration the filters guide, good luck ...
The Following User Says Thank You to mobilagy For This Useful Post:
NOKIA N80 camera problem VIBINDAS_INDIA Nokia Hardware & Hardware Repair 1 12-30-2009 12:21
N73 camra restert hardwar falure @NAYEM121 Nokia Hardware & Hardware Repair 2 11-16-2009 13:21
n80 camera hardware falure problem kiran Nokia Base Band 5 ( BB-5 ) 1 07-19-2007 18:44
n80 camera problem didarilm Nokia Hardware & Hardware Repair 1 03-20-2007 20:22
N80 Big Hardware Problem miecom Nokia Hardware & Hardware Repair 4 10-10-2006 02:52
Page generated in 0.13588 seconds with 11 queries
