Old 01-20-2008, 12:03   #1 (permalink)
Member: 301177
Thanks Meter: 91
6670 showing black shadow
i have a 6670 when on the phone its showing the black shadow i falsh the phone format the user area and also heat the ram flash and uem but prolem is not solve
any idea
thanks
Old 01-20-2008, 19:17   #2 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
U MEAN TO SAY UR MOBILE IS WORKING OK JUST LCD PROBLEM .
Old 01-20-2008, 19:42   #3 (permalink)
Member: 301177
Thanks Meter: 91
HANDSET NOT WORKING ITS AUTO ON AND OFF AND SHOWING THE WITH LIGHT WHEN ON AND CONVERT INTO BALCK AND AGAIN CONVERT IN TO WHITE i also change the lcd lcd ic and make the jumphar in ner to lcd ic
Old 01-20-2008, 19:44   #4 (permalink)
Member: 301177
Thanks Meter: 91
HANDSET NOT WORKING ITS AUTO ON AND OFF AND SHOWING THE WITH LIGHT WHEN ON AND CONVERT INTO BALCK AND AGAIN CONVERT IN TO WHITE i also change the lcd lcd ic and make the jumphar in ner to lcd ic and also the lcd connector
Old 01-20-2008, 20:08   #5 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
IF I M NOT WRONG UR PROBLEM IS LIKE THat .when u on the set ist it shows white lite then slowly fade down and goes off if like that then it has many solutions .ist reball flash ic's one by one if problem persist then u must change or reball upp.
help about a70. black shadow in screen after flashing EMOTION BBSR E-Gold Based Phones 2 07-17-2008 17:52
E90 show black tangqitao1860 Nokia Base Band 5 ( BB-5 ) 2 11-15-2007 20:41
6670 show always ''Memory card corrupted''.. faisi Nokia Hardware & Hardware Repair 2 08-15-2006 06:38
Samsung A800 after flashing shows Black Screen when powers on ?plz help the_frightener VLSI, Conexant, Skyworks and Old Models 17 07-20-2003 06:21
8210 show Black Screen dang Nokia Hardware & Hardware Repair 6 11-05-2002 08:29
Page generated in 0.13882 seconds with 9 queries
