Old 01-24-2007, 14:11   #1 (permalink)
Member: 139043
Thanks Meter: 27
N80 no screen
I have change the lcd and flex but its no use. There is no display as well. What should I do now? Please advise me.
Old 02-23-2007, 11:16   #2 (permalink)
bmg
Member: 67488
I have same problem!
With another two new flex on displey only light!
Any solution for this problem?
Thanks in advanced!
Old 02-23-2007, 13:26   #3 (permalink)
Member: 139043
Thanks Meter: 27
it seems like no one know how to fix this phone
Old 02-24-2007, 07:37   #4 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Arrow
replace or bypass display glass ic.......all fine 100%....do post result
Old 02-24-2007, 07:53   #5 (permalink)
francis1986's Avatar
Member: 324136
Thanks Meter: 99
are u sure that the phone is not water damage!! if its clean then the only solution is to reball omap 10000000% works. I did it.
Regards
The Mobile King Team
Francis Rodrigues
Old 12-09-2007, 05:53   #6 (permalink)
Member: 69679
Thanks Meter: 6
n80 no display
Regards
Francis Rodrigues
can you indicate in your image which is the display ic it will be a big help
Old 12-09-2007, 08:25   #7 (permalink)
Member: 399779
Thanks Meter: 125
Arrow
hope it helps........post result
regtards
PUNEET14884
The Following User Says Thank You to puneet14884 For This Useful Post:
Old 12-13-2007, 14:30   #8 (permalink)
Member: 69679
Thanks Meter: 6
regtards
PUNEET14884
thanks man ill post the result
The Following User Says Thank You to acsxyrile For This Useful Post:
Nokia N80 white screen ( can't call & no welcome nokia tones & keypad sound ) mymiela0419 Nokia Base Band 5 ( BB-5 ) 7 12-22-2008 13:58
Nokia N80 white screen only APE blocks present in flash file but no APE mcu detected xxl121 Nokia Hardware & Hardware Repair 11 10-08-2007 07:37
n80 white screen kannan_fono Nokia Hardware & Hardware Repair 0 01-12-2007 21:25
Nokia N80 White Screen?? Help Needed djskylineuk Nokia Base Band 5 ( BB-5 ) 1 12-08-2006 14:29
N80 purple screen after flash wer_13 Nokia Base Band 5 ( BB-5 ) 7 09-15-2006 22:04
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.15503 seconds with 9 queries
