n81 8gb all keys no working n81 8gb all keys no working only work unlock key and power switch any solution please ?? |
same problem here in 3 sets any one help |
yes me 2 sets is same and n73 too same problem?? any one help?? |
Thanks .................................................. ....................... |
Any Help?? |
brother change strip problem solved 100% tested 3 sets |
check first your flex cable and upper keypad |
they only know thanks means very good haaaaaaaaaa |
dear i chang strip but same problem please send any good pic for this problem |
brother just remove both keypad ic and make jumper to both ics it work like a charm tested by me |
brother change stripe and ic if same response heat lightly cpu other wise check any keys short |
bro, first check side volume key then use other method.................... |
Same issue with me in N81 not working even a single button and volume up down or camera button also not wroking what could be reason behind it? Quote:
all of teses button clean with cts |
