09-07-2009, 14:52 | #1 (permalink) |
Freak Poster Join Date: May 2007 Age: 37
Member: 507372 Status: Offline Thanks Meter: 33 | n95 8gb keypad problem |
09-07-2009, 14:59 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Bro.this problem is flex cable.......... change flex cable............ i m tested it......... |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
09-07-2009, 16:16 | #4 (permalink) |
Junior Member Join Date: Jul 2009 Location: khulna Age: 51
Member: 1081081 Status: Offline Sonork: good Thanks Meter: 2 | keypad is not working properly everytym when i press the number ( 0 ) it automatically dials the few other numbers like OK |
The Following User Says Thank You to KHOKON_KHAN For This Useful Post: |
09-09-2009, 18:47 | #5 (permalink) |
Junior Member Join Date: Aug 2009 Location: philippines
Member: 1098652 Status: Offline Sonork: neltech@cavite Thanks Meter: 15 | try to clean d membranes,probably it shorts,cause of d liquid,water is good conductor! or make a test continuity using a multitester! |
N95 8GB Keypad | ARS.Rehman | Nokia Hardware & Hardware Repair | 12 | 04-21-2013 08:10 |
n95 8gb keypad light problem | selimphone | Nokia Hardware & Hardware Repair | 2 | 03-31-2010 08:46 |
Nokia N95 8GB keypad tone problem | ahl | Nokia CDMA | 2 | 09-20-2009 17:50 |
n95 8gb keypad ribbon replacement | springy | Nokia Hardware & Hardware Repair | 2 | 10-17-2008 15:39 |
N95 8gb keypad don't work | Freshbol | Chinese Models & Cloned Phones | 5 | 08-29-2008 11:03 |
