06-07-2009, 11:16 | #1 (permalink) |
Junior Member Join Date: Feb 2005 Age: 42
Member: 116005 Status: Offline Thanks Meter: 2 | N82 Camera Shutter Not Working I tried replacing my phone housing and after I put it all together, my 5MP camera doesn't work anymore. Normally when you turn the camera shutter open, the camera application will automatically appear on the phone. But now after the dis assembly, the shutter won't respond anymore.When I open the camera application now, Its using the front camera. I'm quite sure that I follow the steps for N82 disassbembly. Does any one here know what makes the shutter trigger the 5MP camera functionality? I badly need help! Thank you so much |
06-25-2009, 19:30 | #2 (permalink) |
Junior Member Join Date: Jun 2009 Location: Bucuresti Age: 42
Member: 1061372 Status: Offline Thanks Meter: 9 | the hole senzor from the camera shutter activate the the camera through a connector (X1440) wich has 3 pins. Check thhis the connector and the pins. I had the same problem beacause one pin was stucked. So, if you haven't a new connector just try to sold some wires between the pins and the senzors hole board. |
The Following User Says Thank You to berryandrei1 For This Useful Post: |
12-19-2009, 13:20 | #3 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Mumbai
Member: 434631 Status: Offline Thanks Meter: 77 | N82 camera not respond N82 camera not respond first check that u have put the magnet on the 5 mpg shutter the magnet works as sencor on the transistor on the main bord so just check the magnet on the shutter. & post reply |
01-20-2010, 14:10 | #4 (permalink) |
Junior Member Join Date: Dec 2005 Location: New Delhi, India Age: 37
Member: 207549 Status: Offline Thanks Meter: 1 | I also have the same problem with my N82. I tried locating the magnet in the old housing, but unable to find one. Nomagnet found either on the old housing or the new onw. I would appreciate if anyone can help me locate the magnet on the shutter. Some picture or tutorial would be great. |
The Following User Says Thank You to parxwebstudios For This Useful Post: |
04-13-2011, 08:06 | #9 (permalink) |
Junior Member Join Date: Aug 2008
Member: 836093 Status: Offline Sonork: [email protected] Thanks Meter: 0 | dear bro tell any one with the help of pic where is the magnet i will be very thankful |
11-23-2011, 13:09 | #11 (permalink) | |
Junior Member Join Date: Nov 2011
Member: 1689026 Status: Offline Thanks Meter: 0 | N82 Camera possible fix Quote:
I just wanna share my experience, this might help others with their n82 phones having problems with their rear camera. My rear camera also has stopped working for almost one month. I tried 'restore to factory settings, hard reset, updating firmware with Nokia Software Updater, Reinstalling firmware, then flashing with phoenix but still my rear camera wasnt restored. Then another day came when I was turning impatient and striving to restore the camera again and I tried reflashing it again with phoenix, and then came the incident when my laptop unexpectedly shut down due to low battery, and then my N82 became a dead phone. I tried to bring it back to life using JAF flasher and phoenix flasher strictly following their procedure in flashing dead phones but none of the two methods restored my N82, so when I grew impatient and worried, I brought my phone to a technician. I never told them about the camera problem of my N82 afraid that they might charge me with a higher price when their flashing method would not only restore my phone to life but also restore its camera as well; I only told them that it was disconnected while flashing with phoenix flashing method so it needs to be re-flashed. So they flashed my phone again, that time using MXKEY FLASHER, and my phone was restored and its camera also to my amusement was luckily restored! So guys, you might wanna try flashing your phone with Mxkey flasher. If you dont know how to do it then have a technician do it for you. Good luck! | |
Nokia N82 camera switch doesn't work | Unicom | Nokia Hardware & Hardware Repair | 0 | 02-04-2010 11:49 |
N82 xenon flash not working | themude | Nokia Base Band 5 ( BB-5 ) | 0 | 12-08-2009 23:07 |
after flashing chinese Weilun N82+ CDMA GSM not working GSM every time insert sim | Elshad Ngage | Infinity-Box | 1 | 09-12-2009 00:23 |
n82 I can not work Touchscreen Calibration | ahmedasmet | Infinity-Box | 4 | 06-25-2008 07:11 |
