n82 keypad 3, 9, *, not working...help hi good day to all of you.... i need help here for my n82 keypad not working for numbers 3, 9, and the asterisk...pls somebody share me keypad ways for this mobile... many thanks, groundheaven |
anyone here pls......:( |
just change the keypad or change the one marked on the picture and the one up left http://forum.gsmhosting.com/vbb/show...48&postcount=5 |
where is than his the problem ? telling us about the result.... ... .... ........ ...... ...... ..... ..... |
Thanks, very use full post. |
IC & full keypad changed but not solved :confused: any Solution |
any help plz |
N82 Keypad Problem Solved My problem has Solved Line at pin 25 of socket X4402 was broken ;) |
thanks IKI but blue marked ic is attached with the key pad ???;;:you can verif . For me i not think |
yes it is conected with some of the keys on keypad |
при разборке n82 отрывается кровать клавиатуры на плате - пропоять кроавть ,нет -заменить эми фильтры |
solution!!!!!!!!! check pin 5 in(at the left side) in keypad socket. |
sir..is there anyone who can give jumper solution to replace the keypad ic of n82??thankssssssss... |
