01-12-2010, 16:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | N900 and N97 Not charging Issue I got N900 and N97 both not showing charging (were bought from Dubai SimFREE) I changed charger ..checked connector from Inside Both were Brand new not used more then few mins.. What can be the cause have any one encounter such issue and have Solved ? Working reply kindly waiting......!!! |
The Following User Says Thank You to Amir-SkillZ For This Useful Post: |
06-27-2010, 19:59 | #3 (permalink) |
Junior Member Join Date: Apr 2008 Location: Philippine
Member: 754421 Status: Offline Sonork: i don't know! Thanks Meter: 3 | Try to change the Charger output, cause it shows not charging when the charger's voltage increases or decreases. hope it will help! |
The Following User Says Thank You to micro_champer For This Useful Post: |
06-27-2010, 22:27 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: May 2010 Location: gsm hospital
Member: 1294693 Status: Offline Sonork: 100.1591739 Thanks Meter: 483 | Quote:
change n3301 usb and charging detector(4347805) n900 change n1104 usb and charging detector(4347413) chek charging connector pad also | |
The Following User Says Thank You to gsmdocter For This Useful Post: |
N97 not charging solution | tantan167 | Nokia Hardware & Hardware Repair | 47 | 02-20-2014 10:54 |
Nokia n97 not charging at all. | 4 u man | Nokia Hardware & Hardware Repair | 3 | 10-11-2010 23:18 |
3310 auto charging and then not charging and then reconnect charger | hooi76 | Nokia Hardware & Hardware Repair | 6 | 08-17-2010 12:25 |
N97 not charging and data cable not seen | usernome | Nokia Hardware & Hardware Repair | 0 | 03-10-2010 18:32 |
N342i not charging issue | pvick | NEC | 2 | 03-11-2009 20:28 |
