N91 Problem Hi, I Have This New Nokia N91 Which Says "hard Drive Not Available". Any Ideas, Thanks. |
common problem on n91 (check back cover contact ) br |
n 91
Hello Quote:
I DID CHECK. EVEN CHANGED THE HDD FROM A WORKING PHONE, BUT STILL THE SAME. HAVE A NICE DAY. |
Hello Hi, Could You Be More Specific As To Where Is The Sensor. Have A Nice Day |
I Have Same Problem After Some Time Handset Gating Hot What Can I Do ? |
hi i had the same problem try to format your hdd by JAF - format file system , and put on battery cover otherwise phone say that "hard Drive Not Available" form me works fine :) |
here is the solution(we do not have to use any of box or sofeware): 1. normally i will turn on the phone and press *#7370# to restore to factory setting first. 2. TAKE OFF BACK COVER. reboot phone by holding the (pen-key), the phone will boot as safemode. (it looks no different from normal mode) 3. go to setting--> harddisk (now you will still see "harddisk is not available") 4. PUT BACK COVER ON (do this slowly). then the phone will work very slow BUT THE PHONE IS NOT HANG. 5. you have to be patient, and press option key, and wait for phone responds, it normally takes from 2mins to 5 mins (some phones responds fast, some phones responds slower, depands how it reads harddisk) 6. after option menu comes up, choose harddisk to format (formatting takes about 15 mins or more, be patient, wait until it finish, after formatting harddisk, every thing will work ok again) note: after put your backcover back, each key you press, phone will respond very slow, because it's reading harddisk, but THE PHONE IS NOT HANG Dear members, more Device hangs when booting Cause: - Corrupt HDD - Defective HDD - Defective device - HDD sticking Cannot access the HDD Cause: - Battery cover not in place - Magnet missing from battery cover - Damaged HDD - Corrupt data on HDD - Poor interconnect between HDD and PWB HDD Corrupt Cause: - Data installed from factory, that was corrupted - Applications installed on the HDD by user, not compatible S60 applications that are not version 3.0 (previous versions) are not compatible with N91. - Application install process to the HDD by user, that are not compatible If an application was copied from another device to a PC and then onto the HDD via mass storage, this will corrupt the HDD. Applications that worked in non-S60 3.0 devices will not work in the N91 or other S60 3.0 devices because of binary incompatability. Example: an application that works in a N70 or 6630 will not work in the N91 or N71. If an application was downloaded from the MMC of these devices and transferred (drag and Drop) into the N91, this would corrupt the HDD and the HDD would have to be formatted to function again. The N91, on startup, will see applications that were copied from the PC to the HDD. It will try to install these applications; this will lock the HDD and not allow access. This problem, with early sw (version 1.0), was only able to be repaired by formatting the HDD with Phoenix, because the USB connection could not access the HDD. Also, if the customer took a backup of a corrupted HDD image, when they restore this image to the device it will have the same fault. If an application was interrupted when it was being installed on the HDD by a power cycle. Applications have to be allowed to install uninterrupted Slow Accessing Applications Causes: SMS, MMS, Themes, and some applications if they are loaded onto the HDD, will cause slow access times. All these items should be loaded onto the devices internal memory and not the HDD. Quick Test tips If the device will not boot: - Restart the device with the battery cover removed If the device boots then there is a HDD issue. If the device boots but can not see the HDD - Make sure the battery cover is in place. - Check that there is a magnet in the B-Cover Use a metal object (a paper clip works) and see if it sticks to the lower right side of the device (opposite to the USB connector) If it does not stick replace the b-cover with a good b-cover. Retest. Testing There are different tools available to test and repair the HDD. They are available from the User Interface (UI), through the “Mass Storage” USB selection when connected to a PC and through Phoenix test software. Depending on the level of corruption on the device, this will limit which tools can be used. If the HDD is not accessible through the UI or the PC, then the last chance to format the HDD is through Phoenix |
nokian N91 Dear sir Nokia N91 :cool:menu key:cool: :eek: ic :eek: :)all trak damege.:) So menu key do not work. Please Give me solution. Regards Gopal Oza. |
Nokia N91 Menu key do not work R4406 ic track damege. so give me solution argent |
where is the magnet in n91 Dear sir please say me where is the magnet in n91 |
