Old 07-31-2008, 21:28   #1 (permalink)
Valkensuit's Avatar
Member: 806365
Thanks Meter: 42
Arrow 6131 does not detect the sim, help
hello friends gsm, I need your help to solve this problem, I have a Nokia 6131 that does not detect the sim. and you spend a fullflash and remains the same, I am afraid that is hardware.
Old 08-01-2008, 05:40   #2 (permalink)
ybru's Avatar
Member: 268154
Thanks Meter: 40
with search option look for "sim ic jumper"
The Following User Says Thank You to ybru For This Useful Post:
Old 08-01-2008, 06:47   #3 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
check chasis!!!!
is chasis is 100% ok then check vsim and sim filter!\
BYTE
The Following User Says Thank You to Byte For This Useful Post:
Old 08-01-2008, 07:07   #4 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
br simply change sim ic near mmc ic i hope u found the and 100% solved post result soon......
Best Regards.
ikram butt
The Following User Says Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 08-28-2008, 15:38   #5 (permalink)
Valkensuit's Avatar
Member: 806365
Thanks Meter: 42
friends. I Have the solution and I would like to share it with you, but until I have 100 post can not do uploads and I have the solution in an image. expect already arrived. thanks for their contributions.
need help.. pc does not detect my SGH-T619 theref Samsung Flashers, Software, Firmware. 1 03-21-2009 15:07
6131 Does not power on on battry but it works perfect while I connect UFS Cabel .:.GSM-ANGEL.:. Nokia Base Band 5 ( BB-5 ) 1 10-25-2007 12:24
Legija does not receive or it does not answer the support email. TORRES UniMoto 0 10-16-2005 18:51
V66 PC does not detect the phone framkie Motorola P2k 0 04-04-2002 22:08
c35 does not read the sim F C x1x to x45/x50 1 10-22-2001 23:19
Page generated in 0.17288 seconds with 9 queries
