09-02-2009, 12:55 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Heidelberg
Member: 458909 Status: Offline Thanks Meter: 33 | N95 8gb Network problem N7520 FEM (had 3 broken contacts), N7540 WCDMA pa, Z7582, Z7503, Z7540, Z7541, Z7501. Now I get no signal when DUAL mode is selected. When i select UMTS mode, i get full signal on MTN simcard. When i then select DUAL mode, I get full signal. When i select GSM mode, i get no signal When I use VODACOM simcard, i get no signal, even in UMTS mode. This is very confusing. As far as i know, gsm mode is 900/1800 mhz. UMTS mode is 1900mhz. What am i overlooking, or might this be a software problem? Please help!!! |
09-02-2009, 14:26 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Bro.this hardwere problem........... try it...N95 8gb network solution here............ http://forum.gsmhosting.com/vbb/showthread.php?t=811705 |
09-03-2009, 08:29 | #4 (permalink) |
Member: 458909 Status: Offline Thanks Meter: 33 | I found this in service manual. What exactly does this mean? Pre-baking These parts are moisture sensitive and must be pre-baked prior to soldering: • RFIC N7505 • Front End Module (FEM) N7520 • WCDMA PA N7540 |
N95 and N95 8GB comunication problem | MobilMan | Universalbox | 7 | 01-22-2009 10:45 |
nokia n95 8gb network no | seyit | Nokia Hardware & Hardware Repair | 1 | 05-28-2008 16:15 |
n95 8gb flash problem | ahmad5175 | Nokia Base Band 5 ( BB-5 ) | 0 | 01-29-2008 06:36 |
