n96 memory in use hi i have big problem n96 mass memory not in use and not work i can't see any file in file manager and only show memory in use i'm sure not software please help thx |
dont touch any hardware !!!! its softwaer problem ... sometimes sms also have the same problem you need to erase everything from phone factory sett full flash everything good 100000% work |
please up to another site this site filtering in my country |
Before replacing something you should check if it is faulty. Better you use schmatic and Service Manual Level 4 for this problem. Also had this problem, everthing was fine except the Thosiba NAND... Do some simple messuring at first: C5255=2,8V R5250=1,8V J4944=1,8v by access cya |
ma problem is tht i try to format drives with mx-key jaf or hwk but drive not show in file system i flash twice earse all phone then flash it again write back up every thin is ok but mass drives not show and phone still restarting |
