12-20-2009, 09:51 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: MobiCare, Mh-50, India
Member: 1019814 Status: Offline Thanks Meter: 653 | N72 sim not valid Detected PKEY: XXXXXXX Card life counter: 78.74% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.17.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. HW version: 7004 PCI version: RFIC version: 150a160f DSP version: rolf_espresso_05wk07v29p1 Retu version: 32 Tahvo version: 53 Production serial number: DQF260463 Product code: 0531541 Module code: 0203073 Basic production code: 0530940 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 353667011573085 IMEI spare to net: 3A 35 66 07 11 75 03 08 IMEI SV to net: 33 35 66 07 11 75 03 08 F9 LOCK STATUS: CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0531541 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\ Scanning for ini files... INI file 0531541.ini is missing. Continue searching for second ini type... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-180\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\353667011573085_CRT_backu p_237168.pm Done! Backup LCK OK! Setting local mode... Reading simlock data... LOCK STATUS: CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: CLOSED -> Lock Data: 00101F Reading imei... Reading codes data... Found codes data... Resetting phone... Waiting for phone... Reading soft info... Reading simlock data... Writing codes data... Unlock Codes: #pw+212975587030173+7# #pw+207069707373897+6# #pw+293628140392519+5# #pw+761373112599828+4# #pw+548649087283990+3# #pw+704117492960061+2# #pw+791020237415811+1# Uploading code to phone... Reseting phone... Waiting for phone... Reading soft info... Unlocking... Error unlocking... Plz anybody tell me what to do next????????????? Thanx... |
12-20-2009, 09:56 | #2 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
Code: CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 better to post in software section luck | |
12-20-2009, 13:08 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 56
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | CONFIG KEY: FFFFFFFFFFFFFFFF PROVIDER KEY: FFFFFFFFFFFFFFFF just check bb5 software area many many times discussed b4 |
n72 sim not valid after writing pm | dereje | Nokia Base Band 5 ( BB-5 ) | 6 | 04-21-2009 19:35 |
n72 sim not valid | sachin00 | Nokia Hardware & Hardware Repair | 8 | 01-31-2009 06:53 |
n72 sim not valid | anumobjay | Nokia Base Band 5 ( BB-5 ) | 1 | 03-11-2008 14:08 |
N72 sim not valid problem | bounouar | Nokia Base Band 5 ( BB-5 ) | 2 | 09-10-2007 14:05 |
N72 sim not valid | Dizemizyh | Nokia Base Band 5 ( BB-5 ) | 7 | 05-22-2007 00:39 |
