03-15-2011, 23:21 | #1 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1241217 Status: Offline Thanks Meter: 1 | N97 mini microphone I think change mic but dont find it, only i find nokia 5800 mic . itīs the same? could by the problem in other parts of pcb? if i reheat mic, can I damage more? please help!! |
03-15-2011, 23:51 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | Reheating mic won't help,you must change it - 5800 one is the same, use hot air under the main board. Don't apply hot air direct on it because you can damage the microphone. Just changed 2pcs today and worked like a charm |
03-17-2011, 20:37 | #3 (permalink) |
Member: 1241217 Status: Offline Thanks Meter: 1 | If I use air hot under the board donīt burn it? when the mic are desoldered, how solder it? using hot under the board too? there is not anyway? I have fear to damage it! thank you for help me!! |
03-18-2011, 16:07 | #4 (permalink) |
Registered User Join Date: Mar 2006 Location: Brazil Age: 23
Member: 252045 Status: Offline Thanks Meter: 7 | Nokia new Microphones Today this new microphones is very different, the new mic have a five terminals, Please check the pins below: 1. L",R conected to gnd? 2. CLK, check the clock signal with frequencimeter or osciloscope? 3. DATA (digital signal out to D2800). 4. VDD - check the voltage? 5. GND After you check the signals, if you signal is ok change the mic. BR James |
x35 microphone problem | platy | Hardware Repair by brands | 8 | 03-06-2002 03:46 |
3310 microphone does not works | Corban | Nokia Hardware & Hardware Repair | 5 | 01-29-2002 15:11 |
T20 (T28/29) Microphones wanted !!!!!!!!!!!!!!!! | N/East Unlocker | Main Sales Section | 5 | 01-24-2002 20:32 |
motorola V 3690 microphone | maclu | Motorola Hardware Repair | 0 | 12-23-2001 19:09 |
Cut a SmartCard to a mini-sim? | davieb | Motorola Old Legacy (EMMI) | 5 | 05-25-2001 18:05 |
