...Need best solution for 2626 contact service.... Hi all 2626 contact service pro..when completily power on just showing nokia then going be contact service..flash ok & when in normal mode select at JAf same case with phone put batt (only showing nokia then going be cotct srvice)..so I try many solution from searching in this forum but problem stiil same.. ...I'v already removed & changed : - conector Lcd & other LCD = ..NOT SOLVED.. - sim ics & make jumper =...NOT SOLVED.. - C2000,R2000 & R2205 =...NOT solved.... finally I tried..Reheat flash IC & reball CPU =....NOT SOLVED... please anybody can help me to fix this strange problem.. best regard |
change uem ic dudeeee |
have you ever tried for same phone type & same problem..Sir.....?? |
run self test by jaf and post resalt find what test is failed after that ill tel u the solution self test is the only one solution for find the reson of Contat servie |
1 is s/w 2 is h/w in s/w u have to flash it other wise u have to chang sound ic in 2626 power ic,sound ic, charging ic allin one that is uem so no dout about it |
2626,2610 Contact Service |
best way to solve this problem first u erase flash then flash and write good pm unlock and full factory settings post the result |
I'v already tried...doesnt work.. All software trik by JAF Already tried but prob still same |
Sorry..double post self test by JAF...All Passed, except LCD test & FLASH CHEKSUM test failed What this the meaning brother?.... thanks |
It also occurs from LCD. So first change LCD from an working 2626, if not ok then try to erase full, do full flash(old version to new), write PM and unlock. If not ok then it must be Hardware. May be CPU. |
do u hav try flashing ?? try do full erase than full flash back and unlock use repair file |
re: Quote:
it's uem case.........boc u have try sof. lcd ect. so try rehot uem ic then flash may be u problem will be ok.... |
