Old 10-21-2011, 18:25   #1 (permalink)
Member: 1638155
Thanks Meter: 5
Post 3110c clk track in fbus missing.plzzz help me.
3110C CLK TRACK IN FBUS MISSING.PLZZZ HELP ME.
Old 10-23-2011, 15:52   #2 (permalink)
Wites OM Tesla's Avatar
Member: 1017374
Thanks Meter: 2,594
>>>>>>>>>>>>>>>>>>pin7
Reball Tahvo>clk_______/\______mbus<Retu,this is how track connected.
The Following User Says Thank You to Wites OM Tesla For This Useful Post:
Old 10-23-2011, 18:48   #3 (permalink)
Member: 1638155
Thanks Meter: 5
Originally Posted by Wites View Post
>>>>>>>>>>>>>>>>>>pin7
sir thanks for reply but rebolling not work because track brocken .can i get this clk supply from any other point on the board or any other solution for clk point..........plzzz help.................
Old 10-23-2011, 19:00   #4 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
system connector for what? Software update or unlock?
Old 10-23-2011, 19:13   #5 (permalink)
Member: 1638155
Thanks Meter: 5
sir for unlock.........................................
Old 10-23-2011, 19:24   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
if u want to restore clk track , only way is solder a thin jumper wire under thavo pin J6 to flash interface pad. remove thavo first then solder jumper wire & resold thavo then.
quite tough job but can possible.
post result
The Following User Says Thank You to .:SARCAR:. For This Useful Post:
Old 10-23-2011, 19:31   #7 (permalink)
Member: 1638155
Thanks Meter: 5
post result
sir for me is verry hard..........treed 2 time but fail'''''''''''thanks for reply............................................b ut sir what is clk n how to work clk in flashing...............is this power suplly or ?????????????
Old 10-24-2011, 11:10   #8 (permalink)
Member: 1017374
Thanks Meter: 2,594
Bro use an microscope & scratch gently with an razor that 7pin & find track in
board then solder a thin wire to coper dot that you will find in board.Good luck
Old 10-24-2011, 16:31   #9 (permalink)
Member: 1638155
Thanks Meter: 5
thank sir but not sucses. i think 3110c board have many test point..........so it possiblel to get this missing print .............so plzzzzzzzzzzzzz try to help me............. thanks again............
Old 10-24-2011, 17:34   #10 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
How to unlock 3110c via USB solution !!! (F.key)
How to UNLOCK via USB NOKIA 3110 Classic using Fenix Key - YouTube
The Following User Says Thank You to indikait For This Useful Post:
Old 10-24-2011, 17:46   #11 (permalink)
Member: 1638155
Thanks Meter: 5
thanks for reply sir but i dont have fenix i have mxkey hti and hwk.............is this possible with mxkey by usb ???????/
Old 10-24-2011, 17:53   #12 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
Old 10-24-2011, 18:10   #13 (permalink)
Member: 1638155
Thanks Meter: 5
i dont understand u..........
Old 10-24-2011, 18:16   #14 (permalink)
indikait's Avatar
Member: 241637
Sonork: 100.1620549
Thanks Meter: 396
mx key not supported..
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
fbus-mbus ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-05-1999 13:46
Page generated in 0.40845 seconds with 9 queries
