Old 09-22-2002, 11:59   #1 (permalink)
Member: 11208
Thanks Meter: 11
Willy 3310 problemm?
Hi.
Willy I have strange nokia 3310 with following pb. When it find network with 4 bar it automaticly turn off.Not switch on untill I press power switch.If I use over voltage 5v then it doesn't power off,remain on but no network after few seconds. I already changed pa,antenna switch, ccont. What I need to do?
Thanks
Old 09-22-2002, 17:46   #2 (permalink)
Member: 1060
Thanks Meter: 10
Re: Willy 3310 problemm?
Gsmsalers,
check first B cover battery connector !then check at Hager Charge pump at N503 , and TXVGSM
BB: check CCONT C242 VTX, C240 VRX ! and try to check TXC from COBBA control and COBBA some GND pin and MCU TXP enable !
Willy
Originally posted by gsmsalers
Hi.
Thanks
Old 09-23-2002, 00:50   #3 (permalink)
Member: 11208
Thanks Meter: 11
Hi.
Can you explain me? I need info about gsm hardware repairing tools. My friend bought 1Gega Herz osciloscope from china. It seems can be used as spectrum analyzer and ordinary osciloscope . Now what is it rf-generator? Also frequency counter? If I have 1Gega Herz osciloscope then no need frequency counter,yeah?
Thanks
Old 09-23-2002, 07:25   #4 (permalink)
Member: 1060
Thanks Meter: 10
Gsmsalers,
it is good to use to measure GSM 900 !
and you need a good probe !
if this oscilloscope has readout function, then you can test it as a frequency counter !
ps. you did spam one same post in other thread , and i have delete it already , please careful next time, thanks !
Willy
Old 09-23-2002, 12:41   #5 (permalink)
Member: 11208
Thanks Meter: 11
Hi.
Thanks for attention. Now what it is rf-generator? Is it some kind of high band frequency generator?
Old 09-23-2002, 16:45   #6 (permalink)
Member: 1060
Thanks Meter: 10
gsmsalers
signal generator :we call SG ..
it use for send signal to phone antenna pad ,
then you check RX path from antenna switch up to COBBA !
Willy
Willy, 3310 network????? gsmsalers Nokia Hardware & Hardware Repair 5 01-15-2003 10:48
Again, 3310 to Willy .... and everyone !! CellM@n Nokia Hardware & Hardware Repair 3 12-06-2002 19:20
TO MR. WILLY 3310 again baraka42 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 11-27-2002 11:23
Willy again 3310 problemm? gsmsalers Nokia Hardware & Hardware Repair 3 10-13-2002 09:58
@willy---about 3310/3330 F C Nokia Hardware & Hardware Repair 3 09-10-2002 11:38
Page generated in 0.16986 seconds with 10 queries
