Old 06-14-2008, 09:30   #1 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
Exclamation Need E65 Display Light Solution
Dear all,
i have E65 display light and upper keyboard light is not working...but under key board is working normaly...any body have the solution?
flexible is ok,led driver is ok and already change betty ic...
br
joni_yang
Old 06-14-2008, 10:35   #2 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear,
Check it may be usefull for u
due to problem to attached the image, please check this link
http://meo786.forumotion.com/nokia-h...7014.htm#13841
Originally Posted by joni_yang View Post
Dear all,
br
joni_yang
The Following User Says Thank You to meo786pk For This Useful Post:
Old 06-14-2008, 14:04   #3 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
Originally Posted by meo786pk View Post
Dear,
i check the resister is ok
thanks for the reply bro...
my set is water damaged...before is power off...after cleaning the pcb,replaced avilsc ic and betty ic the set now everything is ok just no display light and upper key board no light...but under key board light is working ok....
i check the flexible is ok then i changed avilsc ic and betty ic still the same problem
br
joni_yang
Old 06-15-2008, 07:13   #4 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
still no solution...
br
joni_yang
Old 06-15-2008, 10:04   #5 (permalink)
Member: 303799
Sonork: inside outside
Thanks Meter: 59
check flex cable sir.or try jumper lcd led to keyboard led.
Old 06-28-2008, 14:14   #6 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
dear Pic the jumper led point n sold lcd ligth cercut 2 points
need t 230 display light solution rajendrakumar Sony Ericsson Hardware Repair 1 01-22-2015 07:20
Urgent needed Nokia 3500c display light solution? .:MobileLife:. Nokia Hardware & Hardware Repair 14 11-26-2011 06:09
e65 display light help naveen_naveen Nokia Hardware & Hardware Repair 0 10-22-2009 13:47
i need n95 display light solution tiju kkm Nokia Hardware & Hardware Repair 4 08-10-2009 20:16
i need moto roker display light solution vikass Motorola Hardware Repair 0 04-18-2009 08:48
Page generated in 0.17470 seconds with 9 queries
