03-05-2009, 06:08 | #1 (permalink) |
Banned Join Date: Aug 2006
Member: 327362 Status: Offline Thanks Meter: 45 | need help in converting 2610b into 2610 first i write pm than i unlock than i change the both filters from an working 2610 now the problem is all 800/900/1800 mhz signals are in manual search like {AIRTEL IDEA VODAFONE AND CELLONE} BUT WHEN I REGISTER THEM THAN THERE IS NO NETWORK ACCESS HERE IS THE LOG Powering the phone... Writing PM... Field: 1, Record: 0, Len: 120->OK Field: 1, Record: 2, Len: 90->OK Field: 1, Record: 4, Len: 110->OK Field: 1, Record: 5, Len: 2->OK Field: 1, Record: 6, Len: 90->OK Field: 1, Record: 11, Len: 2->OK Field: 1, Record: 12, Len: 2->OK Field: 2, Record: 0, Len: 384->OK Field: 4, Record: 0, Len: 1->OK Field: 4, Record: 1, Len: 48->OK Field: 4, Record: 2, Len: 44->OK Field: 4, Record: 3, Len: 10->OK Field: 4, Record: 4, Len: 8->OK Field: 4, Record: 5, Len: 8->OK Field: 4, Record: 6, Len: 8->OK Field: 4, Record: 9, Len: 5->OK Field: 4, Record: 16, Len: 4->OK Field: 4, Record: 18, Len: 80->OK Field: 4, Record: 19, Len: 4->OK Field: 7, Record: 0, Len: 4->OK Field: 7, Record: 1, Len: 32->OK Field: 7, Record: 2, Len: 4->OK Field: 8, Record: 0, Len: 12->OK Field: 8, Record: 1, Len: 12->OK Field: 8, Record: 2, Len: 128->OK Field: 8, Record: 3, Len: 128->OK Field: 8, Record: 6, Len: 4->OK Field: 8, Record: 7, Len: 8->OK Field: 8, Record: 8, Len: 8->OK Field: 8, Record: 9, Len: 8->OK Done! Powering the phone... Unlocking... IMEI: 011503007859069 ASIC: b SW version: 06.80 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-87\rh86_87__06.80.mcusw Decrypting flash...Done Checking ROM call...Done Checking security function...Done Encrypting....Done Patch status: 00 MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 2C7E0001 <=> SPANSION -> 72NS128N Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x7E2C0100 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 84 Loader is ready... P-key nokia module version 01.02 MSID: 848AF27AD1399E37A02E9DED60 MSID decoded: 9C12BAE900859B2DAA000000 FAID: 5F58BB755F8B780277AC9441 Erasing area: 01000000 - 0101FFFF... Erasing area: 01080000 - 0109FFFF... Perm. Data Restore OK Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 68 Changing mode... Done! NEED HELP URGENT |
The Following User Says Thank You to sunny_luthras For This Useful Post: |
03-05-2009, 07:28 | #3 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 45
Member: 351924 Status: Offline Thanks Meter: 12,467 | Quote:
1)ERASE FALSH 2)FLASH 2610 FLASH FILE 3)UPLOAD THIS PM 4)UNLOCK 5)FULL FACTORY RESET OPEN UR SET 1)CHANGE RX FILTER LIKE THIS PICTURE POST RESULT | |
The Following 3 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
03-05-2009, 07:49 | #5 (permalink) |
Member: 327362 Status: Offline Thanks Meter: 45 | |
The Following 4 Users Say Thank You to sunny_luthras For This Useful Post: |
03-05-2009, 07:57 | #8 (permalink) |
Member: 327362 Status: Offline Thanks Meter: 45 | yes sir handset is flashed with these files MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__06.70.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__06.70.ppm_w CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__06.70.image_w after than i write ur pm all done successfully till end normal mode failed handset not going on now with battery |
03-05-2009, 08:01 | #10 (permalink) | |
Member: 327362 Status: Offline Thanks Meter: 45 | Quote:
i got a 2610 b rh-87 v6.80 first i write pm than i unlock than i change the both filters from an working 2610 now the problem is all 800/900/1800 mhz signals are in manual search like {AIRTEL IDEA VODAFONE AND CELLONE} BUT WHEN I REGISTER THEM THAN THERE IS NO NETWORK ACCESS | |
03-05-2009, 08:09 | #11 (permalink) |
Member: 327362 Status: Offline Thanks Meter: 45 | SHIJILFONOTLY sir yes sir handset is flashed with these files MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__06.70.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__06.70.ppm_w CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-86\rh86_87__06.70.image_w after than i write ur pm all done successfully till end normal mode failed handset not going on now with battery |
03-05-2009, 08:12 | #12 (permalink) |
Member: 327362 Status: Offline Thanks Meter: 45 | Manufacturer's Description is Dual band GSM 850/1900 Weight: 91 g (3.2 oz.) (with battery) Dimensions: 104 mm x 43 mm x 18 mm (4.09 in. x 1.69 in. x 0.70 in.) 970 mAh Li-Ion battery (BL-5C) |
03-05-2009, 12:03 | #14 (permalink) | ||||
UPLOAD PM CHANGE 2 RX FILTER THATS ALL | ||||
converter 2610B to 2610 | hdeyda | MT-BOX | 2 | 02-06-2010 18:16 |
Need help in data converting software | sony_care | GSM Programming & Reverse Engineering | 1 | 01-09-2010 20:13 |
help to convert .abbu into .phb | PatriciaLazzere | Various | 0 | 08-01-2009 21:21 |
How to Convert 2610b to 2610 , 850/1900Mhz to 900/1800Mhz | imran_qasim | Nokia Hardware & Hardware Repair | 4 | 04-19-2007 08:24 |
need help to convert t226 to t230 | GSM SHADOW | Sony Ericsson | 7 | 01-21-2005 02:15 |
