07-03-2007, 20:19 | #1 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 304119 Status: Offline Thanks Meter: 6 | 3200 network I got a nokia 3200 network problem. when i switch on the phone, there is no network. I flash the phone and write pm and manually select network, but it says " no operator found". what can i do to repair the network? is it the problem in the AS or PA or HELGO ? thanks |
07-06-2007, 03:53 | #9 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: K.S.A
Member: 444785 Status: Offline Thanks Meter: 170 | Quote:
and solve your problem jalak.............. | |
07-06-2007, 11:24 | #10 (permalink) | |
Product Supporter Join Date: Jul 2006 Location: BANGLADESH Age: 39
Member: 310330 Status: Offline Sonork: 100.1577334 Thanks Meter: 1,449 | Quote:
no 3200 & 3200b no soft difference its hardware difference.3200 contains 1800 mhz network band ic. your problem is Atina switch problem.change it. or chk this pic- BEST OF LUCK. JHON. | |
08-30-2007, 14:23 | #13 (permalink) |
Insane Poster Join Date: Jul 2006
Member: 319778 Status: Offline Thanks Meter: 5 | my bro you can know what can you do by using search when show you short search and tell you no network you can change ant pad second search appear in no short time you can change ant switch third thing when it show the operator of network you can selcet one of them and disappered you can change pf ic please give me your result your friend hassan from egypt |
3200 Network | dev452005 | Nokia Hardware & Hardware Repair | 1 | 06-06-2009 12:41 |
3100,3200 network problem who is master about that | GSMTURBO | Nokia Hardware & Hardware Repair | 7 | 01-09-2008 20:27 |
3200 network problem | toolsveera | Nokia Hardware & Hardware Repair | 5 | 10-10-2007 08:06 |
3200 network problem | albarka network | Nokia Hardware & Hardware Repair | 1 | 10-08-2006 21:25 |
nokia 3200 network problem | ajayazad | Nokia Hardware & Hardware Repair | 3 | 07-06-2006 14:00 |
