03-29-2005, 11:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 51905 Status: Offline Thanks Meter: 41 | need help with strang 3100 ringer problem when i torn on the phone cant here sound,just littel beep when recieving call no ring but - when i open the gallery menu and brows the sounds i can here the ringer working how can i fix that??? thanks |
03-29-2005, 12:23 | #5 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Bucharest,Romania Age: 46
Member: 5204 Status: Offline Thanks Meter: 35 | with what version did you flash it ? and with what software...? The problem you described is a software problem (you the ringer works when you brouse the galery it means that there is nothing wrong with the hardware part) |
03-29-2005, 19:55 | #9 (permalink) |
Member: 5204 Status: Offline Thanks Meter: 35 | if you did reflash it including mcu+ppm+pm than change audio IC (it is a verry small IC under the UEM near the chargind diode) If this doesn`t help reflow the CPU WBR |
03-29-2005, 20:54 | #10 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Sofia Age: 43
Member: 77941 Status: Offline Thanks Meter: 120 | @shachash if your problem is with very low ring try first to change poliphonick buzzer and check PCB contacts and components near them if nothin must to change small black audio IC regards |
03-30-2005, 20:30 | #13 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: PORT HARCOURT,NIGERIA. Age: 54
Member: 36906 Status: Offline Thanks Meter: 1 | Quote:
08-31-2007, 12:53 | #15 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 301521 Status: Offline Thanks Meter: 12 | hey if your speaker works correctly and buzzer don't works: it z a Hardware problem if ur speaker and buzzer dont works %100 software problem u can find buzzer jumpering with search button. |
need help with a200 white lcd problem | arabian tiger | Chinese Models & Cloned Phones | 1 | 03-17-2010 18:02 |
3100 Ringer problem, & 6230 Incomplete flashing | thechatfriend | Nokia Hardware & Hardware Repair | 2 | 06-07-2008 14:17 |
3100 ringer problem | uncle smallz | Nokia Hardware & Hardware Repair | 5 | 06-07-2008 14:12 |
3100 ringer problem | wasim_mobile200 | Nokia Hardware & Hardware Repair | 3 | 12-17-2006 06:18 |
Need help with my G50 ringtone problem | leunggm1 | Panasonic | 2 | 01-30-2004 01:32 |
