11-05-2004, 00:12 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Algeria Age: 43
Member: 29104 Status: Offline Thanks Meter: 0 | 3310 Signal drops after few seconde from powering ???!! any solution for these big problem ,when switch on signal is good but after few second it drop down, i changed many components ,PA,Antenna switch,...etc . but no result ,any solution guys ??? |
11-05-2004, 07:50 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | check VBATT to PA, look at circuite book if VBATT to PA cut then make a jamper, problem slove, if circuite good change CCONT. nertwork will be back |
11-06-2004, 17:43 | #7 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | do jump for antina switch it will be solve or do serch for this problem in this forum u will found u r problems slotion *********************M.Azam********************* |
11-07-2004, 13:12 | #9 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | First again flash phone (MCU+PPM) and then with "FAID" and "repair IMEI" and possible "unlock with eproms 3.1" ...if still same problem again change PA! |
11-07-2004, 18:09 | #10 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 49
Member: 61294 Status: Offline Thanks Meter: 49 | changing PA , can cause phone not to power on again. please, try a new battery on your phone . post your result ............. bestman. if nor properly applied, this can cause no power on problem. bestman. Last edited by bestman; 11-07-2004 at 18:34. |
11-07-2004, 18:21 | #12 (permalink) |
No Life Poster Join Date: Mar 2004 Location: romania Age: 42
Member: 57035 Status: Offline Thanks Meter: 70 | if pa is OK , antena switch is OK , vbatt to PA is OK ? THEN try to reflow with FLUX / change cobba / reflow change CCONT .... try relfow the FLASH ic !!! |
01-08-2005, 20:20 | #15 (permalink) |
Major Poster Join Date: Sep 2004 Age: 54
Member: 81153 Status: Offline Thanks Meter: 0 | Vbatt to PA Friends, I have seen people saying, check VBATT to PA. What I want to know is.......should there be continuity? or should there actually be 3.6 volts on pins of PA? I have measured in 3 or 4 phones today, and all of them had continuity, but none of them had voltage of 3.6....any suggestions? Regards, Raja3333 |
Nokia 6030 Signal drop and power off after few second | Munir Memon | Universalbox | 3 | 07-21-2008 11:42 |
PLEASE ,please, drop signal after few second 1n 3310 , 6310 i change PA , HAGAR | eng.hamdow | Nokia Hardware & Hardware Repair | 3 | 10-31-2005 09:00 |
8330 signal drop after few secs ... ?? | TRABEL | LG | 4 | 08-16-2005 23:31 |
6230 signal drops after a few seconds | jabran200 | Nokia Hardware & Hardware Repair | 12 | 12-25-2004 13:21 |
3310 hangs up after few seconds | Dream gsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-14-2003 14:06 |
