need tuch solution water damage x3-02 MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Please turn on the phone, and connect the USB cable. Detecting BB5 USB Device... Switching from Normal to Local mode... Detecting BB5 USB Device... Local mode set. Reading Info... Soft Version: V 05.65 Date: 26-11-10 Type: RM-639 (X3-02) Pack: (c) Nokia APE Core version: Product code: 0598209 Product code: 0593642 WLAN MAC: 78CA04DC0F4D Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA II / WCDMA V / WCDMA VIII Original IMEI: 357387-04-******** Production serial: C8E493189 HW Version: 1004 DSP Version: 92_MP2.2_5.63j LCD Version: TPO APE ADSP Version: SIMLock service: SIMLOCK SERVER [0100000A011A] Profile bits: 0000000000000000 Simlock config: 2440700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Open; Data: FFFFFF Block: 2; Lock: 1; State: Open; Data: FFFFFF Block: 3; Lock: 1; State: Open; Data: FFFFFF Block: 4; Lock: 1; State: Open; Data: FFFFFF Block: 5; Lock: 1; State: Open; Data: FFFFFF Block: 6; Lock: 1; State: Open; Data: FFFFFF Block: 7; Lock: 1; State: Open; Data: FFFFFF All locks are open. Security code: 12345 -------------------------------------------------------------------------------- TBB5ReadInfoThread 2.9.5.2863 finished at: 2011/09/16 19:05:08 Done. TBB5SelfTestThread 2.9.5.2863 with filepack 7.88 started at: 2011/09/16 19:05:44 -------------------------------------------------------------------------------- MCU Nokia Version: 1.132, and up to date. SMCU Nokia Version: 1.44, and up to date. Please turn on the phone, and connect the USB cable. Detecting BB5 USB Device... Reading Info... Soft Version: V 05.65 Date: 26-11-10 Type: RM-639 (X3-02) Pack: (c) Nokia APE Core version: Product code: 0598209 Product code: 0593642 WLAN MAC: 78CA04DC0F4D Radio: GSM850 / GSM900 / GSM1800 / GSM1900 / WCDMA I / WCDMA II / WCDMA V / WCDMA VIII Original IMEI: 357387-04-******** Production serial: C8E493189 HW Version: 1004 DSP Version: 92_MP2.2_5.63j LCD Version: TPO APE ADSP Version: SIMLock service: SIMLOCK SERVER [0100000A011A] Profile bits: 0000000000000000 Simlock config: 2440700000000000 Invalid codes entered: 0 / 0 Block: 1; Lock: 1; State: Open; Data: FFFFFF Block: 2; Lock: 1; State: Open; Data: FFFFFF Block: 3; Lock: 1; State: Open; Data: FFFFFF Block: 4; Lock: 1; State: Open; Data: FFFFFF Block: 5; Lock: 1; State: Open; Data: FFFFFF Block: 6; Lock: 1; State: Open; Data: FFFFFF Block: 7; Lock: 1; State: Open; Data: FFFFFF All locks are open. Security code: 12345 Detecting BB5 USB Device... Executing self tests... Passed [58] ST_USB_CHARGER_TEST Passed [0F] ST_TAHVOINT_TEST Passed [2E] ST_SLEEP_X_LOOP_TEST Passed [03] ST_UEM_CBUS_IF_TEST Passed [0C] ST_EAR_DATA_LOOP_TEST Passed [21] ST_SIM_CLK_LOOP_TEST Passed [5D] ST_SIM_LOCK_TEST Passed [5A] ST_SECURITY_TEST Passed [02] ST_PWR_KEY_TEST Passed [45] ST_CURRENT_CONS_TEST Passed [14] ST_BACKLIGHT_TEST Passed [2B] ST_BACKUP_BATT_TEST Passed [2C] ST_LCD_TEST Passed [15] ST_LPRF_AUDIO_LINES_TEST Passed [07] ST_LPRF_IF_TEST Passed [16] ST_KEYBOARD_STUCK_TEST Passed [47] ST_CAMERA_IF_TEST Passed [60] ST_BT_WAKEUP_TEST Passed [65] ST_HOOKINT_TEST Passed [08] ST_BTEMP_TEST Passed [48] ST_MBUS_RX_TX_LOOP_TEST Passed [17] ST_WLAN_TEST Passed [13] ST_KELVIN_BATVOLTAGE_TEST Passed [1A] ST_KELVIN_VIBRA_TEST Passed [1D] ST_KELVIN_CAPACITOR_TEST Passed [1F] ST_KELVIN_MISC_TEST Passed [1B] ST_KELVIN_CHARGING_TEST Passed [74] ST_KELVIN_AUDIO_TEST Passed [3C] ST_KELVIN_XEAR_TEST Passed [67] ST_TOUCH_STUCK_TEST Fail [69] ST_TOUCH_IF_TEST Passed [77] ST_INTERNAL_ANTENNA_TEST Passed [5B] ST_IIC_TEST Passed [75] ST_USB_LOOP_TEST Passed [D1] ST_DIGIMIC_TEST Passed [DE] ST_HEADSET_AMPLIFIER_TEST Passed [80] ST_LED_CONTROLLER_TEST Passed [56] ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed [7C] ST_CDSP_RF_BB_IF_TEST Passed [7D] ST_CDSP_STROBE_TEST Passed [53] ST_CDSP_DIGI_RXTX_IF_TEST Passed [7F] ST_CDSP_RF_SUPPLY_TEST Passed [4B] ST_CDSP_PA_ID_PIN_TEST Passed [00] ST_CDSP_WCDMA_TX_POWER_TEST -------------------------------------------------------------------------------- TBB5SelfTestThread 2.9.5.2863 finished at: 2011/09/16 19:05:56 Done. |
whats connection between water damage touch and software? simply change pad |
dear sir change tuch pad solder tuch ic check track some time when heat pcb its working pl give me solution and whty this test is failed |
dear experts pl give me solution for this tuch test failed pl its very urgent |
need solution urgently pl give me circut digram of x3-02 if you can and cuestomer engery with me pl |
