02-10-2003, 13:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Novi Sad, Serbia Age: 44
Member: 17193 Status: Offline Thanks Meter: 16 | network: 000 00 I have two phones on service behaving like this... Every help is appriciated!!!! |
02-10-2003, 20:25 | #3 (permalink) |
Member: 17193 Status: Offline Thanks Meter: 16 | 3330 both. But: when turned on, they show no network. I go into menu, apply factory settings, and THEN they show 000 00 (as network) and no signal at all. I read in other threads that this malfunction occurs on 6210, too. First phone I almost forgot about, it's here somewhere. The last phone came to me as dead. I changed ccont, but no pwr on. I full flashed it with Dejan box, and it came to life but....... It's not cobba, too. Changed it already. |
02-12-2003, 11:50 | #5 (permalink) |
Member: 17193 Status: Offline Thanks Meter: 16 | Problem solved on this one. -HAGAR-. For me. Full reception, working perfectly. I guess that they are kind of sensitive, so try to put them using temperature as low as you can. |
06-16-2004, 15:12 | #10 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Islamabad, Pakistan Age: 42
Member: 48857 Status: Offline Thanks Meter: 31 | Yes perfectly HAGAR fault. i ve changed it and now mobile is working perfect. In some cases there are some dry soldering in HAGAR section so check it out too |
07-20-2004, 21:25 | #14 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | i have 2 N. 3315 have the same probl, i have change ccont, cobba, hagar, PA, ant.sw, 13 mhz, 26 mhz, when i do manual searching it was shown 000 00, i'm surely all component i toke from normaly phone but there is no result. what should i do ? Just buying the new one ????? Last edited by Unggul; 07-21-2004 at 19:39. |
K850 reads as 000-00 but locked to all | Nosebolt | All UnlockByLogs Server | 2 | 04-05-2008 12:01 |
3310 insted of op. name 000 00 | mtmc | Nokia Hardware & Hardware Repair | 7 | 09-10-2004 02:10 |
New Flash Update Package 03.00.000 | DonaldDuck69 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 06-12-2003 17:00 |
